Go to Post Scrap it and use the cheesey poof's design - vladtheimpaled [more]
Unread 27-01-2009, 23:35
run the trap!!!
Team Role: Human Player
Re: pic: Skunkswerve Module Iso View
Originally Posted by Dave McLaughlin View Post
Hal was a bit quick to insist that we are looking for an alternative to keyed shaft. We encountered a small problem with holding one of our keys in place, but we have already figured out a way to address the problem. Thank you for the quick suggestion of hex shaft, but we intend to stick with the keyed shaft we have now.
If it is machined correctly the key should have almost a press fit so it doesn't twist around. You can hold it in place by simply having spacers on either side of the sprocket/gear to limit its movement or by using a setscrew.
IMO keyways are MUCH easier to make than hex parts. You need a lot of special tools and skills to correctly machine hex parts. Keyways are very easy.
-Philip J. Fry
pic: Skunkswerve Module Cross Section Dave McLaughlin Extra Discussion 35 03-03-2009 15:50
pic: rendered view of iso team 1708 D_Price Extra Discussion 2 15-02-2008 10:21
pic: Isometric View of A 6WD module Cody Carey Extra Discussion 8 04-01-2007 17:19
pic: Iso view CD47-Bot Robot Showcase 19 07-09-2004 17:38
pic: 217 Robot ISO view CD47-Bot Robot Showcase 8 01-03-2004 13:09
