Thread Tools |
Rating:
Display Modes |
Re: pic: Robot Bumpers
It's becoming obvious that I need to officially release the inspector training materials ASAP. The new materials will include a set of "good"/"bad" diagrams that should, I hope, ensure regional-to-regional inspection consistency. Please check the website with the FIRST manuals often for the inspection materials (I'm sure that a Team Update will probably indicate when the docs are available as well).
After you read the inspection materials, do NOT be surprised if your robot inspector deems the above bumper configuration to be ILLEGAL. The Section 8 Robot Rules and various GDC Q&A responses have always required 6" bumper segments on both sides of every "exterior corner". The diagram at the top of this thread does not have the required 6" segments at every corner ("corner" being EVERY vertex in the Bumper Perimeter). From my perspective, I think that R08 would be more painfully clear if the word "exterior" were removed from "exterior corners" and figures 8-2 and 8-3 were updated to either officially declare the unlabeled features to be "NOT OK" or fix them so that they are "OK". Russ Beavis Chief Inspector |
I'd also recommend that the wording of Robot Rule R08-i be modified with wording from related Q&A responses to say something like "BUMPERS must protect all corners of the BUMPER PERIMETER with BUMPERS on both adjoining perimeter segments".
More clear? "Protect" isn't very easy to quantify but it's obvious (at least to me) that the GDC Q&A responses are requiring 6"+ bumpers on both sides that meet in a "corner". Russ |
Dave, I looked carefully at it and I can see where you are coming from now.
![]() Figure 8-2 (Blue Text added by me) Quote:
GDC Q/A Response, "both sides", "curves" My Pro-GDC Analysis: What you are supposed to infer from <R08-J> is that the Figure shows how to protect corners A, B, C, and D. The figure clearly demonstrates "both sides" of the corner as being protected. My Dissent: As a general rule of thumb- the GDC should not provide a figure as an example for a rule that violates other rules in the manual. This definitely creates confusion. The other part of the figure 8-2 which creates confusion is corners E and F. These two corners apparently are not corners and are in fact "curves." From the Q/A response, the GDC will not define a curve. From that my friends, I may make without hesitation and purely for intellectual and kindly debate that I make this claim: In the Scott Hill Image corners A and B are not corners and are in fact "curves" making this configuration LEGAL. |
That picture only shows techniques for mounting bumpers. Trailer hitch could just as easily go b/t a-c or b-d.
For example, why is it that you are just focused on the presence/absence of bumper segments across the lower edge of the robot in the 8-2 illustration ("lower" in the reference frame of the illustration)? If anyone were really on their game, they would also note that upon immediate inspection the robot is also in violation of Rule <R06>, <R10>, <R11>, <R14>, <R15>, <R18>, <R19>, <R20>, <R21>, <R23>, all of the fabrication schedule rules, <R29>, <R32>, <R33>, every one of the power distribution rules (<R38> through <R49>), <R55>, <R56>, <R57>, <R58>, <R59>, <R62>, <R64>, all of the operator console rules (<R79> through <R88>), <R90>, <R91>, <R93>, and probably several other rules. The illustrated robot is also a two-dimensional figure. Two dimensional robots are not allowed in the competition (implicit effects of Rule <R55>, <R58> and <R64> wherein three-dimensional devices must be included as part of the robot). Since it is in violation of Rule <R18> it cannot haul a trailer, thus it cannot participate as a viable entry into the game. So it is in clear violation of both the letter of the rules and the intent of the game. Yet no one seems to have a problem with that. At this point, if you have any common sense at all, you are saying "that is silly, of course the illustration of the robot in figure 8-2 doesn't need a control system included. That is not relevant to the text referencing the illustration, and it would be unnecessary - even distracting - to include all that extra information." That is exactly the point. Neither the illustration nor the text referencing the illustration are saying anything about anything other than the four corners indicted with "OK" or "not OK." Don't assume that there is any more implied information content than that. Last edited by dlavery : 28-01-2009 at 19:32. Reason: typo |
Dave, for a discussion of figure 8-2 involving a Q and A answer see:
http://www.chiefdelphi.com/forums/sh...4&postcount=11 We're trying to take the discussion away from figure 8-2 and judge this configuration based on the original competition manual rules and pertinant team updates and Q and A responses. Russ stated a simple way all of this could have been avoided and possibly yet be mitigated prior to competition. We and we think many others would appreciate a Team Update that clarifies this. |
If the point of tangency (of the change in direction) can't easily/quickly be identified, it's probably a curve. I personally think A and B in the picture are to be considered corners, thus not being a legal configuration. If they had a much broader radius (lets say >8 in.), I'd start to consider them more a curve than a corner. |
In my mind, a legal curve's minimum radius is functionally defined by your ability to bend a solid piece of 3/4" plywood around it without causing your bumper to break any rules (e.g. it must be backed all the way around by frame and remain rigid and strong).
This limit arguably excludes an even larger class of curves than the "I know a curve when I see it" test... |
You see, the arguments are not as simple as they might first appear. ![]() -dave . |
#10
This thread is an_l retentive. Get on with it. Week 4 is half shot. There have got to be other issues with the robot than your robot's rear end. Square it up and move on. The design does not allow picking up from the floor so you got 7 balls to make count. The drivers need allot of practice to make each one of them count. Our team learned from aim high that the human loading of balls requires great skill. With the strategy you have chosen practice and perfection are more important than the robots but. Let this thread die.
#11
Here's a purely hypothetical situation. Let's say that a team designs a chassis in which there are no sharp angles, only rounded ones so their bot isn't actually a polygon, nor does it actually have any corners... Say using a bent-pipe frame rather than straight-pipe? Just curious.
#12
this debate effects other robot orientations than just the one being shown, so it should kinda be resolved before the regionals begin, so dont let the thread die please. This also is not talking specifically about the robot mentioned in the other thread.
#13
I have to agree that this is a vital issue, I would hate to see teams disqualified over this rule. I believe that this orientation is Illegal as stated within the manual in which clearly states Compliance with all rules is mandatory this orientation is not in compliance with all rules and is therefore illegal.
#14
).Related to that, the various responses in the Q&A forums have made it pretty clear that reviews of specific designs will not be provided. But you can expect direct questions about how a rule will be applied to be answered. So when posing your question, instead of asking "here is a picture of my design - tell me if my corner bumpers are legal," you might ask "Given rule <R08-A> and <R08-I>, does this mean that a bumper segment of at least six inches in length is required on each side of an exterior corner of the robot?" I am pretty sure that the second form of the question will be answered (actually, I am pretty sure that it has already been answered multiple times, but some here obviously remain unconvinced). -dave . |
#15
An answer to that ought to quickly affirm whether or not the bumper arrangement surrounding A and B is legal. Or, maybe not. ![]() |
| pic: PD-1345's 2008 robot without bumpers | Arefin Bari | Robot Showcase | 2 | 23-02-2008 23:44 |
| pic: Finished 1024 2008 Robot (without black bumpers to show detail) | Qbranch | Extra Discussion | 5 | 19-02-2008 20:51 |
| pic: Purple Bumpers - 418 | leeweek | Extra Discussion | 5 | 05-04-2007 00:12 |
| pic: RC 1736 bumpers | bam_415 | Extra Discussion | 5 | 27-02-2007 20:12 |
| Robot bumpers | EricLeifermann | Technical Discussion | 15 | 12-01-2007 02:18 |
