Thread Tools |
Rating:
Display Modes |
Re: pic: Robot Bumpers
If the point of tangency (of the change in direction) can't easily/quickly be identified, it's probably a curve. I personally think A and B in the picture are to be considered corners, thus not being a legal configuration. If they had a much broader radius (lets say >8 in.), I'd start to consider them more a curve than a corner. |
In my mind, a legal curve's minimum radius is functionally defined by your ability to bend a solid piece of 3/4" plywood around it without causing your bumper to break any rules (e.g. it must be backed all the way around by frame and remain rigid and strong).
This limit arguably excludes an even larger class of curves than the "I know a curve when I see it" test... |
You see, the arguments are not as simple as they might first appear. ![]() -dave . |
This thread is an_l retentive. Get on with it. Week 4 is half shot. There have got to be other issues with the robot than your robot's rear end. Square it up and move on. The design does not allow picking up from the floor so you got 7 balls to make count. The drivers need allot of practice to make each one of them count. Our team learned from aim high that the human loading of balls requires great skill. With the strategy you have chosen practice and perfection are more important than the robots but. Let this thread die.
Here's a purely hypothetical situation. Let's say that a team designs a chassis in which there are no sharp angles, only rounded ones so their bot isn't actually a polygon, nor does it actually have any corners... Say using a bent-pipe frame rather than straight-pipe? Just curious.
this debate effects other robot orientations than just the one being shown, so it should kinda be resolved before the regionals begin, so dont let the thread die please. This also is not talking specifically about the robot mentioned in the other thread.
I have to agree that this is a vital issue, I would hate to see teams disqualified over this rule. I believe that this orientation is Illegal as stated within the manual in which clearly states Compliance with all rules is mandatory this orientation is not in compliance with all rules and is therefore illegal.
).Related to that, the various responses in the Q&A forums have made it pretty clear that reviews of specific designs will not be provided. But you can expect direct questions about how a rule will be applied to be answered. So when posing your question, instead of asking "here is a picture of my design - tell me if my corner bumpers are legal," you might ask "Given rule <R08-A> and <R08-I>, does this mean that a bumper segment of at least six inches in length is required on each side of an exterior corner of the robot?" I am pretty sure that the second form of the question will be answered (actually, I am pretty sure that it has already been answered multiple times, but some here obviously remain unconvinced). -dave . |
An answer to that ought to quickly affirm whether or not the bumper arrangement surrounding A and B is legal. Or, maybe not. ![]() |
| pic: PD-1345's 2008 robot without bumpers | Arefin Bari | Robot Showcase | 2 | 23-02-2008 23:44 |
| pic: Finished 1024 2008 Robot (without black bumpers to show detail) | Qbranch | Extra Discussion | 5 | 19-02-2008 20:51 |
| pic: Purple Bumpers - 418 | leeweek | Extra Discussion | 5 | 05-04-2007 00:12 |
| pic: RC 1736 bumpers | bam_415 | Extra Discussion | 5 | 27-02-2007 20:12 |
| Robot bumpers | EricLeifermann | Technical Discussion | 15 | 12-01-2007 02:18 |
