Go to Post I believe everyone should give a modicum of repsect to each person they meet for the first time. After that it is up to them as to whether to give you a reason to increase that respect or detract from it. - Al Skierkiewicz [more]
Unread 01-28-2009, 07:34 PM
gorrilla's Avatar
gorrilla gorrilla is offline
AKA: adam spears
FRC #1557 (12voltbolt)
pic: 1557 3rd week progress
Unread 01-28-2009, 07:37 PM
gorrilla's Avatar
AKA: adam spears
Re: pic: 1557 3rd week progress
so this is what we've been working on for the past 3 weeks or so...
the square aluminium in the middle of the "thresher' goes inside of a 4in.pvc pipe with pnuematic tubing on the outside to push the ball up the "screw"
Adam Spears
2010: Goveners Award.
2010: UL Saftey award.
Unread 01-28-2009, 07:39 PM
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Very nice looking Archemedies screw.
Whats it's capacity? Will the center turn when fully loaded? Whats the load rate into the shooter?
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 01-28-2009, 07:47 PM
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
That looks awesome! Good luck!
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 01-28-2009, 07:48 PM
gorrilla's Avatar
AKA: adam spears
1.it should hold 20-25 balls(depending on how much they "smush" inside the thresher)
2. it does,(powered by a keyang)the pnuematic tubing lays flat against the pvc tube after a certain pressure point(that way we can just leave it running the entire match)
3. one at a time right now, we dont have a lot of space to work with...
ps.the shooter rotates left and right(via a denso)
...its weighs suprinsingly little(maybe 50 pounds at the most)
...its going to have an awsome paint scheme too...
Adam Spears
Unread 01-28-2009, 08:38 PM
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Anticipate lots and lots of full speed multi-bot collisions, including getting pile-driven from two sides at once. The frame in the picture, or somethig wrapped around it, is going to need to be sturdy enough to survive the punishment.
Unread 01-28-2009, 08:48 PM
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
You might wanna make sure thats 60 inches tall
Unread 01-28-2009, 08:52 PM
FIXIT's Avatar
FIXIT FIXIT is offline
FRC #0120 (Red Dragons)
FIXIT is a jewel in the roughFIXIT is a jewel in the roughFIXIT is a jewel in the roughFIXIT is a jewel in the rough
Is your robot a six or four wheel system -- not sure if you have a wheel at the front edge?
Cleveland's Team - The Red Dragons
Youth Technology Academy ---Cuyahoga Community College
Unread 01-28-2009, 09:07 PM
EricH EricH is online now
I'm fairly sure it is. It's just on a cart in the picture.
Looks like you still have some work to do. Stop posting pictures, get the robot readier, and post some more pictures!
Unread 01-28-2009, 09:08 PM
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
In that order.
Unread 01-28-2009, 09:16 PM
Pat Arnold's Avatar
Pat Arnold Pat Arnold is offline
I think I over-think things...
FRC #1557 (12 Volt Bolt)
Pat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond repute
The majority of impact during play should occur at the bumper level...this is a welded tubular frame, hopefully it will be okay.
"Gorrilla" might have used optimistic math; I'd guess the "spinning tube of death" will hold closer to 18-20 orbit balls at one time.
2005 -2008 MARS Team 1523 Mentor/NEMO Member
ME's wife & Tim's mom
Geocaching is my other obsession..."Using multi-million dollar satellites to find Tupperware in the woods".
Unread 01-28-2009, 09:36 PM
gorrilla's Avatar
AKA: adam spears
i renamed it the "thresher"
4wd, we figured wheels at the front edge would'nt be needed?
its 5.5 balls around, and theres 4 levels on the spiral and they squish quite easily
ps.its 59 inches tall....
you should see how stiff it is since Craig welded, it nearly impossible to flex it
IF we can find pool noodles....
Adam Spears
Unread 01-29-2009, 11:14 PM
Ian H. Ian H. is offline
FRC #5026 (Iron Panthers)
Ian H. will become famous soon enough
I really like the idea of cutting down on polycarb by only having the strip running up where the ball will touch it, also looks cool like that. cool, simple and seemingly obvious, but I hadn't thought of it before.
1557 rolling chassis gorrilla Robot Showcase 4 01-19-2009 10:38 PM
pic: 3rd iteration swerve Aren_Hill Extra Discussion 5 03-21-2008 07:09 PM
pic: Team 1345, end of 3rd week. Arefin Bari Extra Discussion 14 01-29-2007 08:44 AM
pic: 3rd mecanum prototype TheOtherGuy Extra Discussion 4 11-16-2006 12:55 AM
