Go to Post Like many researchers before me, I look and read about what my peers are doing and developing, and then incorperate the best of them into my ideas or change my focus because of them. - Wetzel [more]
Unread 29-01-2009, 01:14
CraigHickman
Re: pic: twenty zera niner hub
What platform did you render this in? If it's Inventor, you might want to check the resolution settings, as you should be able to clean this up a lot. Solidworks has similar settings.
Poke around, there's much to be learned from the rendering engines in each!
pic: 2009 Mecanum Hub - Team 1595 willson.thomas Extra Discussion 23 06-11-2008 17:02
Sprocket with hub or without? Vikesrock Technical Discussion 5 15-01-2008 01:14
Hub for Wheel attachments Lavapicker Kit & Additional Hardware 5 09-01-2007 19:27
Grants awarded to Twenty-seven Schools for FIRST Robotics Program KathieK FIRST In the News... 13 19-12-2006 20:58
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
