Originally Posted by Woody1458
http://img48.imageshack.us/img48/9659/teasernegtm1.jpg
With negativity removed.
Also by counting the tubes you can approximate that this roller is 24" long, so they are using a wide robot style. Also the diameter is about 3"~4" based on the fact that pneumatic tubes are .25 in OD. Also the fact that the tubes aren't squared off but have pointed cuts lead me to believe that they had to be either threaded through something or squeezed into something tight. Maybe a foam covered roller? Like a paint roller?
It could be a roller, or is it a main drum in the center of their robot??
