Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Unread 29-01-2009, 12:11
run the trap!!!
Team Role: Human Player
Re: pic: Anyone doing this?
No we didn't decide to do this, it wasn't even really considered b/c it wouldn't have worked with our design.
But I would like to know what kind of rubber those "rubber tubes" are, both Akash's and the Disco-bot's.
We are going to have an intake roller, and slipping a rubber tube over it for traction sounds like a really elegant solution (as opposed to wraping neoprene whether stripping around it )
-Philip J. Fry
Unread 29-01-2009, 12:21
MrForbes MrForbes is offline
Have you looked into Plasti Dip spray rubber coating?
they have it at a local Sutherlands store
Unread 29-01-2009, 14:58
Again this isn't a design we're using.
The rubber that we used last year on our bot's rollers was actually the lining of a rubber innertube. We had just enough at a mentor's house to use and it worked perfectly.
Unread 29-01-2009, 16:22
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
Our team is using a variant of this, which allows for using less rollers to ascend to the top, and also allows the roller system to double as ball storage (without any "hopper", we can hold around 20-25 orbit balls). In fact, we've managed to get the rollers to do everything manipulative on the bot, without any major modifications to the roller system at any point (that is, it's almost symmetrical over a horizontal line through the middle).
We'll post some pictures once we have a 'bot up and running, which hopefully won't be too much longer.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 30-01-2009, 00:18
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
The black mat we use is drawer liner from Wal-mart. We use zip ties to squeeze the black mat around a pool noodle.
If we encounter a ball jam the noodle will eventually slip on the 3/4" pvc rod preventing the #25 chain from skipping or stalling the motor.
Check out our gallery for more details, http://2009.discobots.org/node/34
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 30-01-2009, 00:25
We're using black mat from Walmart too, on our helix drive. We have flaps of it sticking out, brushing the balls up the helix. Kind of hard to see in the video because it's on black ABS pipe.
http://www.chiefdelphi.com/forums/sh...ad.php?t=73219
pic: Does anyone know who this belongs to?! Dylan Gramlich Extra Discussion 3 20-01-2007 19:14
What are you doing this year? 358_4_Life Rules/Strategy 4 16-01-2007 17:23
pic: Can anyone identify this man? ;-) CD47-Bot Extra Discussion 22 07-07-2006 09:46
pic: Can anyone else do this ? CD47-Bot Extra Discussion 8 16-03-2003 12:20
Why is FIRST doing this??? Harrison Technical Discussion 8 25-01-2003 19:44
