Go to Post I think Team 45 is cloning Andy. Anybody who has pitted next to them should agree that they are first class students running a first class team. - IKE [more]
Unread 29-01-2009, 01:14
114Klaatu0x72's Avatar
114Klaatu0x72 114Klaatu0x72 is offline
DQN
AKA: Sean
FRC #0114 (EagleStrike)
114Klaatu0x72 has a spectacular aura about114Klaatu0x72 has a spectacular aura about114Klaatu0x72 has a spectacular aura about
Send a message via AIM to 114Klaatu0x72
pic: twenty zera niner hub
CraigHickman
Re: pic: twenty zera niner hub
What platform did you render this in? If it's Inventor, you might want to check the resolution settings, as you should be able to clean this up a lot. Solidworks has similar settings.
Poke around, there's much to be learned from the rendering engines in each!
Unread 29-01-2009, 13:03
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Unless you have already made these, I would recommend you put a fillet in there.
pic: 2009 Mecanum Hub - Team 1595 willson.thomas Extra Discussion 23 06-11-2008 17:02
Sprocket with hub or without? Vikesrock Technical Discussion 5 15-01-2008 01:14
Hub for Wheel attachments Lavapicker Kit & Additional Hardware 5 09-01-2007 19:27
Grants awarded to Twenty-seven Schools for FIRST Robotics Program KathieK FIRST In the News... 13 19-12-2006 20:58
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
