Re: pic: Team 2826's Drive Base
umm is that robot even legit?
According to the robot wheel rule were it states the wheels must be parallel to the frame at all times and perpendicular to the ground at all times...? |
" ... The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). ..." Nothing about being parallel to the frame, only the axis parallel to the ground. |
Wow! That looks pretty sweet for a rookie team! I wish I was still at Fondy Fire so I could come up there and check ya guys out! I wish you the best of luck! Also, I heard you guys are pretty top notch at Charger Invitation...! :O Looking great.
| pic: drive base idea | dbell | Extra Discussion | 23 | 07-26-2008 11:11 AM |
| pic: DeWalt drive base | dbell | Extra Discussion | 16 | 09-18-2007 05:10 PM |
| pic: 195 Drive Base | Tom Bottiglieri | Robot Showcase | 24 | 02-16-2006 12:50 PM |
| pic: 254 completed drive base | CD47-Bot | Robot Showcase | 1 | 02-26-2004 04:34 PM |
| pic: 1083 drive base | CD47-Bot | Robot Showcase | 11 | 02-24-2004 02:04 PM |
