Go to Post Nah, I never crash or break anything... - Elgin Clock [more]
Unread 29-01-2009, 19:54
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: pic: Team 383 teaser
Originally Posted by ducttapedude View Post
It could be a roller, or is it a main drum in the center of their robot??
Listen to those pink guys, they sure can smell a drum roller five thousand miles away
Originally Posted by Woody1458 View Post
Also by counting the tubes you can approximate that this roller is 24" long, so they are using a wide robot style. Also the diameter is about 3"~4" based on the fact that pneumatic tubes are .25 in OD. Also the fact that the tubes aren't squared off but have pointed cuts lead me to believe that they had to be either threaded through something or squeezed into something tight. Maybe a foam covered roller? Like a paint roller?
The "normal" (pre-filter) picture shows a ball bearing at the end of the ~4" OD (10 cm, actually) PVC tube. The perspective threw you off big time, the roller was 54 inches long when we took the picture, it's been trimmed a foot or so after that.
We chamfered the pneumatic tubes to make it easier to insert them - there's a 0.8 mm interference fit between tube and hole, and we got a lot of calloused students and mentors
Manoel Flores da Cunha
Brazilian Machine
Team # 383
pic: Team 383 teaser Manoel Extra Discussion 11 10-02-2008 09:07
Team 383 teaser video Manoel Robot Showcase 5 31-01-2008 22:46
pic: Team 383 mecanums Manoel Robot Showcase 10 31-01-2008 19:37
pic: Team 383 2007 bot corel draw Aldabe Extra Discussion 4 10-03-2007 10:18
pic: team #2247 come to visit team #383 mayah Extra Discussion 1 29-01-2007 12:30
