Go to Post I swear, at IRI, Gary and I only talked about coming up with a plan to do away with Billfred, we didn't actually do anything... yet... - MissInformation [more]
Unread 30-01-2009, 00:58
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
pic: View of our Harvester 842
Unread 30-01-2009, 00:59
Martino's Avatar
Martino Martino is offline
FRC #1825
Martino is on a distinguished road
Send a message via AIM to Martino Send a message via MSN to Martino
Re: pic: View of our Harvester 842
how did you attach the FP motor to the shaft? my team is working on attaching one for our picker-upper.
thanks
Unread 30-01-2009, 01:00
MrForbes MrForbes is offline
Looks like they used a piece of PVC pipe and cut slots in the end of it.
Unread 30-01-2009, 01:43
CraigHickman
Out of curiosity, how well does the Window motor powered belt work? We'll have one assembled with that motor by the end of the weekend, I'm just curious if it's fast enough in practice (our math said it is).
Unread 30-01-2009, 03:01
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Depends on what you define to be "fast enough". The Denso motor has a free speed of 84 rpm's. If we assume the rollers will run at that speed (ignoring friction in the system), with a 2 inch diameter roller, and belt on both sides (ie sandwiching the ball), thats a travel rate of about 8.8 inches per second. For our system specifically, this simply isn't fast enough for us to be competitive, but every design is different. Looks great 842! Teams like you and 1726 should get special recognition for the openness you both have with your design process.
PS. I realize you did get the 2008 Chairmans Award, which is pretty good i guess , but maybe a ribbon or something would be nice as well...
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 30-01-2009, 03:52
bmarick bmarick is offline
FRC #2374 (Crusader Bots)
bmarick is on a distinguished road
congrats.
nice we have a similar pvc wheel design. bu we are using a piston to get the balls to the top of our system.
Unread 30-01-2009, 09:55
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
that bot looks really cool from the front.
295 Team Captain
Unread 30-01-2009, 11:39
Tim Spry's Avatar
Tim Spry Tim Spry is offline
FTC #0201 (FEDS)
Tim Spry is an unknown quantity at this point
That looks like a clean design. How does it work with multiple balls in the chute? We were worried about rolling the balls against each other and having the straps on the balls catch on each other.
Unread 30-01-2009, 13:12
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Looks good, have you done any tests?
Unread 30-01-2009, 15:38
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Is that chassis really legal? You might make the 2/3 rule, but certainly there's a rule that every corner must be protected by bumpers (at least 6 inches) on each of the corner, right?
SBPLI Long Island Champions 2003 2005 2006
SBPLI Semi Finalists 2007 2008 (#1 seed) 2009 (#1 seed)
Galileo Finalists 2009 (thanks 1717 and 2775)
Unread 30-01-2009, 15:41
FRC #0234 (Cyber Blue)
Rookie Year: 1942
All:
There are already numerous debates and threads and posts about the bumpers on 842. This thread is about the harvester.
Please refrain from commenting on their need for bumpers.
Thanks -
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
Unread 30-01-2009, 15:44
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Haha, they most definitely know this by now. I believe they plan to install flat front faces on both sides in order to mount bumpers on them.
Unread 30-01-2009, 15:46
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Sorry didn't see it :X
Unread 30-01-2009, 20:47
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Thumbs up Re: pic: View of our Harvester 842
I love the swiss cheese design on the frame, thats allot of weight u took off.
Unread 30-01-2009, 23:57
CraigHickman
That's not their frame...
pic: CD 7 ball harvester BlazinFire47 Extra Discussion 21 14-05-2012 09:56
pic: Ball Harvester falconmaster Extra Discussion 46 25-01-2009 15:33
pic: Women of 842! f falconmaster Extra Discussion 0 10-01-2009 23:31
pic: A closup view of our prototype worm-crab drive system. AndyB Extra Discussion 6 20-01-2008 00:02
pic: Rear view of our 07 'bot Cody Carey Robot Showcase 7 16-02-2007 12:29
