Go to Post Blue shirts are ALWAYS watching. And they have spies everywhere. Always be on your best behavior, and be polite to every volunteer at the event. - Andrew Schreiber [more]
Unread 30-01-2009, 16:17
Re: pic: Chassis Base
Originally Posted by ScottieDo555 View Post
did you guys grind the welds. if so its not the best idea. or so ive herd.
Most of the strength of the weld comes from the inner corners where the frame members meet. Corners, such as the ones seen on the open front of this frame, are fairly weak as it is since they're on the edge; but they will hold throughout an entire 3-competition season (as was seen with us the last 2 years). Cross members, such as the middle cross member seen in the picture, are plenty strong with those two welds.
Hence, grinding the 'top' and 'bottom' surfaces does not significantly weaken either type of join so long as the welds on the inside corners are done properly. Grinding is also necessary if you plan to properly powder coat the frame...the bumps severely detract from the final look of the robot.
GitHub
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
c-base chassis issue? wolfeman Kit & Additional Hardware 11 04-01-2009 21:46
pic: 6w/d Chain base kajeevan Extra Discussion 9 19-08-2008 22:54
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
pic: 1024 Base Michael Long Robot Showcase 4 17-02-2006 08:53
