Go to Post One team at the UTC regional scored over 2100 points in autonomous alone. I was highly impressed. - Greg Marra [more]
Unread 30-01-2009, 17:53
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
pic: Now We are Legal
Unread 30-01-2009, 17:56
Re: pic: Now We are Legal
Ya know, theoretically we could create a bumper perimeter that has no 'edge'. If the outer frame member were a continuous piece that was bent to form the corners, I think that would satisfy the rules. Curves are stronger than corners anyways, and so long as a team could bend plywood they'd be ok.
Looks good enough for this year though.
GitHub
Unread 30-01-2009, 18:10
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
See Team Update 8.
Unread 30-01-2009, 18:28
Originally Posted by Joe Ross View Post
See Team Update 8.
Aww.
GitHub
Unread 30-01-2009, 18:39
joeweber's Avatar
Coach team 1322
That was our first though to turn the corners into curves. Good thing we did not do it- per update # 8.
Unread 30-01-2009, 21:38
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
You might want to add some shims to that robot, to bring the new frame extensions in line with the trailer hitch. Otherwise, the back of those extensions will lie inside of the (convex) bumper perimeter polygon, and therefore, any bumpers attached to them will be non-standard, and illegal (for extending outside of the robot volume).
And upon closer inspection, it looks like your plastic cover and its mounting screws also extend past the bumper perimeter. You may want to also shim the trailer hitch outward slightly, to account for this fact.
I know it's only an inch. For the same reasons that "it's only an inch" is not a valid response to "your robot is too tall", you should address this issue.
Unread 31-01-2009, 12:13
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
Maybe a shim for the lexan.......... but as far as the bolt heads, they can pocket the plywood so that the wood backing of the bumper is flush against the frame.......
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
ARE TRACTION WHEELS LEGAL??? zivo123 Technical Discussion 3 07-02-2008 13:09
are gas shocks legal? team877 Rules/Strategy 3 31-01-2007 21:56
Are 2 RC contorllers on 1 bot legal? Tottanka Rules/Strategy 10 13-01-2007 21:17
Are Capacitors Legal? mechanicalbrain Electrical 32 22-11-2005 21:06
Are these mat'ls legal? archiver 2000 1 24-06-2002 00:15
