Go to Post Don't be too distracted by the shiny robots, and the games they play. Enjoy them, but keep your eyes on the real prize(s). - gblake [more]
Unread 01-02-2009, 00:39
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
pic: 1351 Wheel Modules
Unread 01-02-2009, 00:41
run the trap!!!
Team Role: Human Player
Re: pic: 1351 Wheel Modules
Cool!
You'll be like the 3rd Nor-Cal team to do swerve.
Is it just me or are the vertical miter-gears plastic?
-Philip J. Fry
Unread 01-02-2009, 00:46
Woodworker88 Woodworker88 is offline
Shop Rat
AKA: Michael Fagan
FRC #0190 (Gompei and the H.E.R.D), FRC #0114 (Eagle Strike)
Woodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the rough
Looks great. Were the side plates CNC'd or waterjetted?
2005-2008 FRC Team 114 (Los Altos, CA) Lead Machinist and Shop Manager
2009-Present FRC Team 190 (Worcester, MA) Lab Manager
Worcester Polytechnic, Mechanical Engineering 2012
2009 Boston Regional
GM Industrial Design, Regional Champs (thanks 61 and 1099)
"Do or do not. There is no try." -Yoda
Unread 01-02-2009, 00:54
Cool!
So its not just me who saw that.
You think that it'd be a problem in the future?
Unread 01-02-2009, 02:20
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Depends, what material is that plastic?
R.C.
MadTown Robotics Team 1323
Unread 01-02-2009, 10:55
Sam N.'s Avatar
FRC #1351 (TKO)
Oh yes - the vertical gears are made of nylon. I don't think mating a steel to a nylon is too uncommon - it's a quieter solution than steel to steel (so I'm told) and doesn't require super-precise positioning. The nylons are also a lot less expensive than their steel counterparts ($4 instead of $30). Still, if the nylons do chew themselves apart, we have a spare set of steel gears.
The parts were CNC'd by Meadows Manufacturing, our local sponsor.
What other Nor-Cal teams are doing swerve?
Mitty Robotics Alumni
TKO 1351
Unread 01-02-2009, 12:43
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
In this situation, I think that having plastic gears is actually pretty acceptable due to the fact that this is not a game of extreme loads. The wheels would break friction and slip on the surface before any teeth would strip.
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
Unread 01-02-2009, 17:06
CraigHickman
...Don't forget about the force of suddenly changing directions when at full speed. Most Plastics don't like that too much.
Unread 01-02-2009, 18:17
Sam N.'s Avatar
FRC #1351 (TKO)
Our torque and acceleration control algorithms should prevent sudden direction changes at high-speed.
...should
TKO 1351
Unread 01-02-2009, 18:39
gorillamonky gorillamonky is offline
FRC #0696
gorillamonky is an unknown quantity at this point
even if you try and change directions at high speeds, i don't think the friction will allow you to do so, so even if your software fails, the laws of physics should hold
it wasn't like that when we shipped it
Unread 01-02-2009, 20:08
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
...should
I'd be a bit more concerned with the CoF change as you go from free spinning on the regolith to traction on the carpet.
Otherwise, looks great.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
pic: cRIO Model with I/O Modules in Inventor Ed Sparks Extra Discussion 5 22-12-2008 22:17
pic: 254/968 Swerve Modules! Travis Covington Robot Showcase 52 23-02-2008 09:47
pic: 1351 teaser sciguy125 Extra Discussion 7 29-01-2006 15:23
pic: 1351 Teaser Paolo Extra Discussion 1 07-02-2005 17:34
pic: 1351 camera mount sciguy125 Robot Showcase 6 05-02-2005 09:11
