Go to Post I'm always afraid of what the GDC will come up with... Their sanity is often questioned... :D - thefro526 [more]
Unread 02-02-2009, 08:56 AM
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: pic: Custom Wheels
how well do they grip the balls, thats one issue I've foreseen, is that your flywheels won't impart enough momentum on the balls in the time that they are in contact, do you plan to say wrap them in Velcro?
Is now an engineer thanks to FIRST.
Unread 02-02-2009, 09:06 AM
MrForbes MrForbes is offline
gum roughtop tread works really well, there are other materials also that can grip the balls well. Velcro affects the fabric on the balls, so it's probably not the way to go.
Unread 02-02-2009, 10:40 AM
run the trap!!!
Team Role: Human Player
They're never going to touch the balls.
We'll use wedge-top or neoprene rubber for traction on the roller surface.
-Philip J. Fry
Unread 02-02-2009, 11:07 AM
RogerR's Avatar
RogerR RogerR is offline
AKA: Roger Riquelme
FRC #3844 (Wildbots)
You appear to have misunderstood me when I said "vast quantities of balls very quickly." Think 10 balls in a fraction of a second
We actually modeled our shooter using rotational momentum, and imagined that the balls being fired were "collisions" slowing the wheel down. Adding the flywheels greatly improved consistency. Recharge went from about 1 second down to like .2 seconds. Of course we'll have to see about my math
They weigh 2.5 lbs. each. We know how much the final bot will weigh from CAD and this is a perfectly acceptable amount for us.
I'm curious about your set-up; are you using some sort of clutch system to link these to your 'shooter'? traditional wisdom says that by adding rotating mass, you increase spun-up time (I assume this is what you mean by 'recharge'), though I doubt that an orbit ball would significantly effect the RPMs of these beasts.
Ironically, one of my teams went the exact opposite direction, minimizing roller mass, and instead using the shooting motors themselves to give a high rate of fire.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 02-02-2009, 12:19 PM
run the trap!!!
Originally Posted by RogerR View Post
...traditional wisdom says that by adding rotating mass, you increase spun-up time (I assume this is what you mean by 'recharge'), though I doubt that an orbit ball would significantly effect the RPMs of these beasts.
Yes that is correct.
Spin up time will be reduced, but less speed will be lost per shot, so it will be easier to maintain speed.
By constantly spinning the drum slowly we can ramp it up to firing power quickly whenever the need arises.
It is useful to reduce mass from the center of the rotating object, since this mass will not be spinning as fast as that on the edges. This is why we milled out the center. All the mass is on the periphery.
We actually built a very similar dual-ball shooter in '06 that suffered a great deal from recharge. Sitting on top of the ramp, it could only get the first two balls in before it lost speed.
-Philip J. Fry
pic: 114 Custom Wheels CraigHickman Extra Discussion 7 02-01-2008 01:01 AM
custom wheels hiimcristhian General Forum 4 12-21-2007 02:52 AM
pic: Custom Plate Brandon Martus Extra Discussion 5 05-17-2006 12:41 PM
pic: Team 521 Custom Frame Steve P Extra Discussion 9 02-01-2005 11:19 AM
pic: Custom Built Stopwatch Kyle Fenton Extra Discussion 18 12-18-2004 08:57 PM
