Go to Post I don't care if you use hot dogs for wheels. If you're scoring points, and you fit the strategy, it's fine. - evanperryg [more]
Unread 04-02-2009, 13:03
tanmaker
Re: pic: 2745 S.A.R. Week 4
Originally Posted by zachjo View Post
looks intesesting. I've seen the tubing used with a roller on several robots, how do you mount the tubing in the roller?
Drill the hole a tiny bit bigger than the diameter of the pneumatic tubing, then load up the holes with hot glue. Push the pneumatic tubing into the hols, and the extra space will allow the hot glue to harden and keep the tubing where it is. It works pretty well.
Just pushing the tube into tight holes will not work, you need some glue to keep them in place.
pic: Blizzard X - Week 4 Mr. Lim Extra Discussion 9 30-01-2009 14:36
MOEmentum FYI - Week 3: It's Week Three Already?!? Mr MOE General Forum 0 18-01-2009 19:23
pic: 97: Week 4 ZZII 527 Extra Discussion 6 05-02-2008 15:45
MOEmentum: Week 3 - It's Week 3 Already? Mr MOE General Forum 3 22-01-2008 10:16
FIRST to reduce 6-week building period to 5-week archiver 2001 12 24-06-2002 01:27
