Go to Post You win Worlds by innovation. You win Worlds by determination. You win Worlds by engineering a robot so solid, that it successfully completes the game. - Zach O [more]
Unread 04-02-2009, 19:04
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: FRC488 - Xbot 2009 - IX
In our case, our fundamental strategy hasn't really changed at all -- just a lot of significant details in its implementation. As we worked through the design over the last several weeks, we made a lot of mistakes and changes and discoveries, all of which came with some number of band-aids and unplanned additions.
By starting over, we were able to take account of everything we'd learn and include all of the subsequents requirements in our design from the start. So, with some concessions to the design of the existing drivetrain, we've ended up with something that's more robust, lighter and more successful in accomplishing what we intend to do. We put in two very long days over the weekend and are caught up again. With luck, we'll be able to get the whole machine together by Sunday.
The robot is pretty simple, all things considered. The drive is 4WD with a single CIM on each side running through a custom gearbox. The overall ratio is 8.75:1. The intake roller has pneumatic tubing bristles that and a quarter round backing that bring the balls up to the conveyor system. The conveyor system consists of a pair of individually driven belts -- each powered by a FP motor, AM Planetary and the same gearbox we're using on our drive. Not shown is a flap at the top of the conveyor that will push the balls back into the hopper as the come out of the belting. That flap is "normally-closed," such that it covers the belting when we dump balls out.
The hopper can store ~15 balls and measures 14" x 35" x 24" or so. We'll get balls out by raising the height of the floor, essentially, and pushing the balls upward. They then roll over the flap mentioned above and into the opponents goal. The plan, of course, is for this to happen as quickly as possible and so that mechanism is driven by the remaining two CIMs, again through the same gearboxes as those on the drive.
Also, for the record, I don't advocate shooting the engineers.
--Madison--
...down at the Ozdust!
Unread 04-02-2009, 20:40
JOhnch181 JOhnch181 is offline
FRC #1294
JOhnch181 is on a distinguished road
I count 6 cims in your design?
Unread 04-02-2009, 21:24
Madison's Avatar
FRC #0488 (Xbot)
All of the gearbox assemblies have a CIM in them by default and it looks like I didn't change the configuration of the conveyor belt gearboxes to show the FP motors with AM planetarys. The robot has only 4 CIMs.
--Madison--
Unread 04-02-2009, 21:33
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Are you guys using a standard four wheel tank drive?
Unread 04-02-2009, 21:40
Madison's Avatar
FRC #0488 (Xbot)
Yes, simple four-wheel drive with traction control of some variety or another thrown in the mix. It's nothing quite as fancy as your crab drive.
--Madison--
Unread 06-02-2009, 12:10
Matt times Matt times is offline
FRC #2585
Matt times is an unknown quantity at this point
Question Re: pic: FRC488 - Xbot 2009 - IX
can it rotate w/ the trailer attached
Unread 06-02-2009, 13:34
Madison's Avatar
FRC #0488 (Xbot)
The drive train alone -- which is <50 lbs. with battery -- was able to navigate our small field with a trailer attached.
--Madison--
FRC488 - team xbot presents X8: The Ocho Madison Robot Showcase 24 21-02-2008 14:19
pic: XBot 08 4 Fred Sayre Extra Discussion 8 12-01-2008 14:40
pic: XBot Electronics Day 2 Fred Sayre Extra Discussion 14 08-01-2008 00:37
pic: XBot 2007 electronics panel Fred Sayre Electrical 31 14-02-2007 00:28
pic: Xbot vs. Cheesy Poofs, Round 2. Madison Robot Showcase 16 27-10-2006 00:18
