Go to Post this thread made crave bacon so badly that I am now, as I write this, cooking 2 pounds of it. :o - gvarndell [more]
Unread 05-02-2009, 00:20
Johnny's Avatar
Johnny Johnny is offline
We do it for the pizza
FRC #1266 (The Devil Duckies)
Johnny has a spectacular aura aboutJohnny has a spectacular aura aboutJohnny has a spectacular aura about
Re: pic: Rosie Robotics first time doing Swerve
The output and drive sprockets look like a 1:1 ratio; the cluster's appear to be a 12:1 reduction just from the looks of it. So yeah, basically tough boxes.
Unread 05-02-2009, 07:44
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
Ya its toughbox with optional ratio to give us a 8.5:1
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 05-02-2009, 07:54
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Wow that seems like over kill when you have very low traction. We tested our robot and found that power has nothing to do with this game, even in a pushing match.
Looks good though
Unread 05-02-2009, 08:19
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Looks good though
Au contraire! Power has everything to do with the design challenge of driving on the "regolith"!!!
The control of the power, how it is managed and delivered to the wheel is the key. Whether you manage it through software or through multispeed gearboxes, the team that manages it most effectively will have a big advantage.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 05-02-2009, 08:28
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Dana and Rosie,
Looks nice, that ring at the bottom really helps but needs to be a good bearing surface. Have fun!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 05-02-2009, 08:30
AKA: Dana P. Henry
Originally Posted by Al Skierkiewicz View Post
Dana and Rosie,
The pods will be nested into a matching "ring" of delrin.
Unread 05-02-2009, 11:55
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
those look excellent, what i was trying to get my team to build but it isnt currently working.
Gearing them down does give you an advantage, because you will never reach a top speed of a high speed gearbox why do you need it? a slower one makes for higher torque at lower speeds, usually it is a trade off torque for speed, but if you can never get enough acceleration to go full speed trading off for speed is useless. You may not need the torque either but if it ever came down to it the torque would be needed before the speed.
Unread 05-02-2009, 12:07
MrForbes MrForbes is offline
Very nice! Are you sure this is the first time you've done it?
Unread 05-02-2009, 15:37
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I understand what you're trying to say, but you need to think about that statement a little more.
The reason you're unable to accelerate is because you're unable to transmit torque (rotational force) effectively to the driving surface. Friction (specifically static friction) is the limiting factor in how much torque you can transmit. Having torque beyond that isn't going to help you much.
Applying more torque than your traction is going to cause slippage.
Unread 05-02-2009, 15:50
CraigHickman
Those things are enormous! (and GORGEOUS!)
I'm curious, could you elaborate on some of your choices for doing this? Specifically, why mount the motor on the module?
Unread 05-02-2009, 17:13
aka Shawn Burgen
Well we were looking at trying to keep the weight centralized over the wheels. We also were thinking about suspension on the pods, it would be only 1/4 in travel anyways to absorb some of the vibration on the floor.
Team 839 FTC Mentor
Unread 06-02-2009, 09:37
AKA: Dana P. Henry
One other factor on why the CIM is mounted in the pod is for the traction control system our code guys have been working on, each wheel needs it's own motor and this was the easiest way to provide a full range of motion as well.
pic: Swerve protoype finished just on time Aren_Hill Extra Discussion 9 18-03-2007 14:13
pic: My first Lego Swerve Drive Ken Leung Extra Discussion 5 16-08-2006 23:56
First Time Here & Vex Robotics Kit jeffmorris General Forum 11 11-09-2005 20:38
Rosie Robotics hosts ASME meeting at Agawam HS Rosiebotboss General Forum 0 09-02-2005 14:05
Rosie Robotics off season project (w/MIT) Rosiebotboss General Forum 0 10-11-2004 22:59
