Re: pic: Rosie Robotics first time doing Swerve
The reason you're unable to accelerate is because you're unable to transmit torque (rotational force) effectively to the driving surface. Friction (specifically static friction) is the limiting factor in how much torque you can transmit. Having torque beyond that isn't going to help you much. Applying more torque than your traction is going to cause slippage. |
Those things are enormous! (and GORGEOUS!)
I'm curious, could you elaborate on some of your choices for doing this? Specifically, why mount the motor on the module? |
Well we were looking at trying to keep the weight centralized over the wheels. We also were thinking about suspension on the pods, it would be only 1/4 in travel anyways to absorb some of the vibration on the floor.
One other factor on why the CIM is mounted in the pod is for the traction control system our code guys have been working on, each wheel needs it's own motor and this was the easiest way to provide a full range of motion as well.
| pic: Swerve protoype finished just on time | Aren_Hill | Extra Discussion | 9 | 18-03-2007 14:13 |
| pic: My first Lego Swerve Drive | Ken Leung | Extra Discussion | 5 | 16-08-2006 23:56 |
| First Time Here & Vex Robotics Kit | jeffmorris | General Forum | 11 | 11-09-2005 20:38 |
| Rosie Robotics hosts ASME meeting at Agawam HS | Rosiebotboss | General Forum | 0 | 09-02-2005 14:05 |
| Rosie Robotics off season project (w/MIT) | Rosiebotboss | General Forum | 0 | 10-11-2004 22:59 |
