Go to Post I got dragged into FIRST against my will, and it was the best thing that's ever happened to me. - Liz C [more]
Unread 05-02-2009, 22:07
B - Morris's Avatar
B - Morris B - Morris is offline
FRC #2702
B - Morris will become famous soon enoughB - Morris will become famous soon enough
pic: Toughbox Gear, destroyed
Unread 05-02-2009, 22:08
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Re: pic: Toughbox Gear, destroyed
Did you properly lube the gearbox prior to testing?
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 05-02-2009, 22:14
I've heard of similar experiences with both the 12 and 14T this season.
Unread 05-02-2009, 22:17
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Related questions that spring to mind are if you checked that the output shaft turned freely before powering the motors, if you were running the motors through an appropriate breaker, if you put the e-clip on the output shaft, etc, etc.
Given the super slippery floor this year, I can't see a freely rotating drivetrain doing this to a toughbox. Nor should you be able to do easily do this with appropriate breaker protection on the drive train.
The only way I can think of for a nice loose drivetrain to do this to a gear is if you have some wicked shock loading on it from your control system going from full forward to full reverse instantly and repeatedly.
Unread 05-02-2009, 22:18
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
This is kinda scary. We have experienced some tolerance issues with the andymark extended output shafts as well which is slightly disappointing. It seems that the hex portion is slightly not concentric with the 1/2" round portion. We are also using the aluminum cluster gears and it will be interesting to see how they hold up. They should be ok since the forces on the drivetrain in this years game are quite low but only time will tell.
Mentor 2415
Unread 06-02-2009, 01:18
You may consider trying the Macro mode on your camera (it usually has an icon that looks like a flower).
Anyhow, we experienced a near identical failure with AndyMark 12 tooth pinions on a CIM motor, mating to an AndyMark 50 tooth gear. We run at +.003" between the theoretical pitch circles. The gearbox rotated freely when assembled, but when running, we noticed wear and steel dust almost immediately. After approximately two hours of running, the teeth were nearly completely gone. Before they wore completely down, they turned to sharp points. We showed several professors of Mechanical Engineering at a local university who were just as shocked and baffled as we were.
It appears the gear tooth profile may not be a true involute curve as it should be. The gear teeth appear to be sliding against one another, rather than more of a rolling contact motion. My best guess is that something is wrong in the gear forming/cutting process, since the application/design we are using these gears in is not different really from any year past, and we have never experienced this accelerated wear before. I'm guessing that the pressure angle is not 14.5 degrees, or the curve is not a true involute.
However, I have not looked at it in too much detail, and there may indeed be something wrong on our end. We plan to hardness test the gears eventually, and perhaps harden new ones.
EDIT: We are trying new gears with grease, per Paul's recommendation. We'll post here again after more testing.
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
we have had similar tolerence problems from AM products, we had an extended shaft strip the hex part, it must have not been heat treated.
295 Team Captain
Unread 06-02-2009, 08:22
B - Morris's Avatar
FRC #2702
Thanks everyone for the feedback.
I didn't assemble the toughboxes, so I can't honestly say whether it was lubed up or not, but the students (with a mentor) that did it, followed the instructions provided. I still can't see how packing it with grease could solve this problem, as it seems like the gear is too soft, but I'm no expert.
PS sorry for the poor quality, the only camera I had available was on my phone.
Base Driver/Team Captain - Team 1680 (2005 - 2007)
Mentor - 1680, 1503, 1114 (2008)
Mentor - 2702 (2009)
FLL Coach - 6965, 7796 and 8007 (2008)
Univ. of Waterloo
Mechatronics - Class of 2012
Unread 06-02-2009, 08:43
President, VEX Robotics, Inc.
B-Morris,
Please listen to this post very carefully:
You must lube this gearbox or you will get the failure shown in your picture!
The Am toughbox uses the same basic gears that was used in the 2005 Kit of Parts. Andy Baker, JVN, and I designed that original gearbox and it also had to be lubricated. They do not need much grease, just put some on the teeth. These gears are plenty hard for our application.
Team 217 has been using these exact gears since 2005 and we have had ZERO problems and we have used them on 3 motor gearboxes and robots with much more power than this year.
By the way, I am an expert as I design gears for industrial robots that have to run 24 / 7 and last for 10 years.
Please, please, please lubricate these gears with grease and you will never have a problem.
Paul
Unread 06-02-2009, 15:24
B - Morris's Avatar
FRC #2702
Thanks Paul.
We are going to get some replacement gears and make sure our toughboxes are properly greased for the future.
Hopefully this picture will help other teams realize grease is needed before they destroy their gears too.
Univ. of Waterloo
Unread 06-02-2009, 15:28
MrForbes MrForbes is online now
I've worked on cars for years....the gears used in automotive transmissions and differentials are made of very very hard steel, and will last for a very long time with proper lubrication. Without lubrication, they will be destroyed in a matter of miles (I've done it myself by forgetting to add oil to a differential on a car I built).
Use grease! add a little more grease if you aren't sure exactly how much you need.
Unread 06-02-2009, 20:26
gauntletguy gauntletguy is offline
AKA: Eric Nelson
FRC #2771
gauntletguy is an unknown quantity at this point
Send a message via AIM to gauntletguy
However you do not want to add so much grease that it goes onto the shafts as our team had learned the hard way. A mentor told some of our students to grease the gears but they greased all of it and the keys on the CIM shafts fell out on all of them almost every time we drove the robot.
They had to be cleaned with rubbing alcohol, but now we have the problem solved.
pic: Universal Chassis with Toughbox Adapters ajlapp Extra Discussion 1 28-12-2008 23:19
pic: 1024's Toughened Toughbox Qbranch Extra Discussion 3 19-02-2008 21:01
toughbox gear/shaft slippage wireties Motors 11 01-02-2008 12:34
Cubs curse ending? Steve Bartman ball to be destroyed tonight! 2/26 D.J. Fluck Chit-Chat 6 26-02-2004 23:15
