Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Unread 06-02-2009, 13:40
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Electrical Board Top View
Originally Posted by team63 View Post
...it was designed to help in weight distribution with the battery as a major weight factor.
I actually did an aircraft-style "weight & balance" calculation on our controls. I wanted to find out exactly how far to the side the cRIO had to be in order to evenly balance everything. It came out very nice.
In the end, removing one of the Digital Sidecars and some of the NI modules messed with the results somewhat. I do think lightness is more important than perfect balance, so I'm not upset at all.
pic: Top Down Gearbox View RMS11 Extra Discussion 11 13-08-2008 15:45
pic: Virginia's DREAM top view falconmaster Extra Discussion 7 25-01-2008 18:49
pic: Top view Cheesed robot falconmaster Extra Discussion 4 18-01-2008 12:03
pic: A View From the Top CMB Extra Discussion 2 10-01-2007 22:21
pic: Top View of Shaft Drive MAteo9944 Extra Discussion 2 30-12-2006 20:59
