Go to Post A team pulls together when things get rough. - Aignam [more]
Unread 07-02-2009, 08:40
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: pic: 612 Teaser #2
Steering is via front wheel Ackermann, using independent steering motors with shaft encoders on the steering axes. (There wasn't enough space to use the standard mechanical Ackermann link.) Each drive wheel has a quadrature encoder to ensure we get the correct wheel speed while turning.
Here's a sketch of the system's geometry, and the trig functions we are using in LabVIEW:
We use the inside front wheel's steering angle to drive the outside wheel's angle, and the outside front wheel speed to drive the other 3 wheels' speeds.
Using LabVIEW, these calculations were quite easy. It's an excellent tool, and a real time saver.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
pic: 612 Teaser nahstobor Extra Discussion 12 05-02-2009 11:15
pic: Team 612: 2009 Drivetrain Teaser nahstobor Extra Discussion 7 04-01-2009 03:13
Animated GIF: 612 teaser time! Frinkahedron General Forum 4 10-01-2008 19:07
pic: Team 612 Drivetrain Teaser #1 Pnakovich Extra Discussion 5 25-01-2007 22:06
Team 612 Teaser RoboMadi Robot Showcase 5 12-02-2006 19:00
