Go to Post You might want to read...the Manual very carefully. . - dlavery [more]
Unread 07-02-2009, 13:27
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
pic: team 549 bumper solution to OUR problem
Unread 07-02-2009, 13:30
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: pic: team 549 bumper solution to OUR problem
The rules are pretty hard to understand, but the Q&A is hard to understand as well. The only part of the bumpers that will be counted tward length will be the cross sections that have all elements (plywood, cloth, noodle, aluminum angle) that means the 3 inches which stick off the edges (because they do not have plywood on them) do not count. I will post the Q&A accordingly when I find it. We spent a whole day trying to figure out if this was legal, but between the multiple answers on Q&A over this subject, the reality is pretty clear.
EDIT 1: you cannot bring plywood outside your frame, or even into the corner. reread <R08> I can't rembmer which clause but i think its M (there is a diagram on the second page of <R08> explaining what I mean.
EDIT 2: here is the link to the definitive answer http://forums.usfirst.org/showthread.php?t=11743
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 07-02-2009, 14:28
AustinDpOwers89's Avatar
AustinDpOwers89 AustinDpOwers89 is offline
AustinDpOwers89 is infamous around these partsAustinDpOwers89 is infamous around these parts
the entire length of a 6 in bumper segment must be backed by a structural portion of the robot.
Unread 07-02-2009, 14:29
tanmaker
I hope you guys's won't have to do too much work on your chassis to fix this.
Unread 07-02-2009, 14:32
Steakboy-58 Steakboy-58 is offline
FRC #0549
Steakboy-58 is an unknown quantity at this point
That person has very nice hands... Should be a hand model. Very nice!!
Unread 07-02-2009, 14:54
dtengineering's Avatar
AKA: Jason Brett
Actually, while there are several rules covering bumpers, the GDC pro-actively took the step of addressing how these rules would affect design in Team Update #2 published wayyy back in early January.
Look at the last page and you will see that no robot can have an opening greater than 26" across, and "long and narrow" robots are limited to 16" across. Time to take out the TIG and reduce the opening a bit... should be easy enough to do... but do I detect the frame narrowing towards the rear of the robot? That might be an area for bumper concern, too... hard to tell from this angle.
Jason
Unread 09-02-2009, 00:11
I moisturize....... several times a day
TEAM 549
Unread 09-02-2009, 11:16
dragonrulr288's Avatar
dragonrulr288 dragonrulr288 is offline
AKA: Abby
FRC #0216 (ROBODAWGS OTL)
Team Role: Student
dragonrulr288 is a jewel in the roughdragonrulr288 is a jewel in the roughdragonrulr288 is a jewel in the rough
Aren't you able to use one pool noodle and wrap it around that edge?
288 Robodawgs 216
Unread 09-02-2009, 11:54
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What rule leads you to that possibility?
Even if you did wrap "soft parts" around the corner, the GDC has been quite clear in saying that you still need at least 6 inches of "hard parts" behind the bumpers on each side of the corner. That's what "protect" in <R08>I is supposed to mean.
Solution to camera problem techkid7 Programming 1 12-01-2009 08:42
pic: Banebots carrier plates problem & solution Elgin Clock Extra Discussion 14 10-03-2007 07:50
pic: Brownies visiting team 549 Macdaddy549 Robot Showcase 5 17-02-2006 18:40
