Go to Post I personally hope they change the terrain of the playing field ... if only to "level" the playing field. - Daniel_LaFleur [more]
Unread 08-02-2009, 10:04
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: pic: Sidecar problem
Originally Posted by JohnBoucher View Post
It appears to be the only issue. Is C6 necessary and does removing it affect anything?
Kate from FIRST stated in the aforementioned Q&A link:
Originally Posted by Kate
It's confirmed. The C6 capacitor is essentially redundant and therefore unnecessary. The remaining C4 capacitor has sufficient specifications to provide filtering for the 6V servo power supply. It may provide a slight reduction in noise in the 6V servo power supply but we have been unable to detect any negative effects via testing at FIRST HQ.
Fortunately, the Digital Sidecar has conformal coat and, as a result, a loose C6 capacitor will NOT result in any electrical shorts within the module.
We do recommend that teams open the case and remove the loose component.
http://forums.usfirst.org/showpost.p...04&postcount=8
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Sidecar Debug NinjaSpawn94 NI LabVIEW 6 07-02-2009 10:48
Digital Sidecar Problems cabbagekid2 FRC Control System 13 31-01-2009 17:23
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
connecting Jaguar to Sidecar Lakedaimon Electrical 2 15-12-2008 01:04
Missing Standoffs on Sidecar psyco_klown Electrical 3 03-12-2008 19:40
