Go to Post Don't limit programming to just hitting keys, there is a lot of logic/design involved. - Mike [more]
Unread 08-02-2009, 22:10
KevinReid's Avatar
KevinReid KevinReid is offline
FRC #2609 (Beaver worX)
KevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to behold
Re: pic: Yeah!! We finally finished making Orbit Balls!!
Try the Six Million Dollar Man... Classic
http://en.wikipedia.org/wiki/The_Six_Million_Dollar_Man
Unread 09-02-2009, 14:40
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Originally Posted by OScubed View Post
Ours will probably be more robust than the real ones. The real ones use a cheap plastic connector that is easily broken. These are pop-riveted together for each strip. Not to say they won't break - just that they're pretty tough. We're actually concerned that these will be more robust than the real balls which is why we're not replacing the few real ones we got so that we can use those for our official "testing".
After making our balls, we wanted to do some testing with broken bands. It took many throws as hard as people could into a concrete floor to get both pop rivets to come out. The Lexan never broke. The same type of throwing quickly broke a real ball. In retrospect, it would have been easier to drill out the rivets, but throwing them was more fun.
Unread 09-02-2009, 14:45
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
We did similar testing of our adhesive-bonded practice balls - no failures at all.
We also used hot glue to join the fabric ends. It's faster and easier than sewing and also is quite robust (no separated seams after an impromptu soccer game).
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 10-02-2009, 16:18
Robert103's Avatar
Robert103 Robert103 is offline
Rob Small
FRC #0103 (Cybersonics)
Team Role: Scout
Robert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to behold
Send a message via AIM to Robert103
We found that balls pop riveted/glued together acted differently than the store bought balls, do the balls you made still flex like they do?
Unread 10-02-2009, 17:18
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Slightly different. Yes, we thought of this too. They are a little stiffer than the store-bought kind but they flex enough so that there won't be any problems.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 13-03-2009, 19:44
Lara Surmak's Avatar
Lara Surmak Lara Surmak is offline
Lara Surmak is infamous around these partsLara Surmak is infamous around these partsLara Surmak is infamous around these partsLara Surmak is infamous around these partsLara Surmak is infamous around these partsLara Surmak is infamous around these partsLara Surmak is infamous around these partsLara Surmak is infamous around these parts
What did you make the balls out of?
We tried using lexan that was the same thickness as the plastic that the original moon rock was made from, but the ball that was made is unsquishable, and therefore useless to our team.
Unread 13-03-2009, 20:01
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
They used polycarbonate(lexan). I'm not sure of the thickness.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-03-2009, 13:59
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Our balls were substantially stiffer than the factory manufactured ones, but were still usable by most teams for testing and practice. One suggestion to make them more flexible is to use tape to connect the ends rather than the rivets.
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 14-03-2009, 16:22
artdutra04's Avatar
VEX Robotics Engineer
I wish I had known about this back when we wrote the white paper, but the material inside a real Orbit Ball is polypropylene. McMaster sells 4'x8' sheets of 1/16" thick polypropylene for $29.16 and 3/32" thick sheets for $41.20.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-03-2009, 18:33
And that is cheaper than Lexan, for sure! But same thing for us, by the time we knew what the material was, we had already purchased and cut the lexan.
But we love our slightly stiffer and WAY more durable balls! And so did the teams that came to our rally because there were lots and lots of them.
Cynette
pic: 1511 Drivetrain & Orbit Balls Kims Robot Extra Discussion 21 28-01-2009 11:58
pic: Team 1592 Found Some Orbit Balls roboticsrocks Extra Discussion 6 19-01-2009 00:18
pic: Trailer with 19 orbit balls Pjohn1959 Extra Discussion 3 08-01-2009 02:37
Animation Finally Finished Velaes 3D Animation and Competition 1 04-02-2005 10:42
INVENTOR AWARD FINISHED....finally ggoldman Inventor 7 22-03-2002 11:57
