Go to Post Its not the event that matters - its the preparation for the event that matters! - Ken Patton [more]
Unread 09-02-2009, 03:00
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: pic: Team 665 Ready to Go - Fan Lunacy Teaser
FINALLY!!! A robot that is bumper legal!!!
Except that piece of plywood the motors are attached to is sticking out beyond the bumper perimeter. You may want to get that checked out!
Unread 09-02-2009, 03:53
Blackstarr904's Avatar
Blackstarr904 Blackstarr904 is offline
Junior Mentor
FRC #0904 (D3)
Blackstarr904 is an unknown quantity at this point
Wow.... ive seen a lot of pretty interesting bots this year... but this is one of the most unique.... i would have never thought of using prop blades as propultion until now.
Good luck
Unread 09-02-2009, 13:22
HalcyonInk HalcyonInk is offline
You mean that /doesn't/ go there?
AKA: A. Reeves
FRC #2910 (Jack in the Bot)
HalcyonInk is an unknown quantity at this point
I've seen a lot of robots that have the basic "refridgerator" look going - box on wheels with ball vomiter. This... this is unique. I hope it works out for you!
Unread 09-02-2009, 13:33
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We need to talk about robot safety.
Those weights need to be properly secured, you could break a toe.
Unread 09-02-2009, 13:45
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
With something as awesome as that, who cares about safety!?!
Hi!
Unread 10-02-2009, 19:51
1jbinder 1jbinder is offline
FRC #0852
1jbinder is an unknown quantity at this point
How is this going to turn?
Thanks,
Julian
Unread 10-02-2009, 23:12
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Thanks,
Julian
Yeah, this was more or less a joke teaser. You can check out the thread that Eric pointed to, it has the actual design. This was a testing stand to see what kind of thrusts we could get out of various setups. We have a standard 6WD drivetrain and the fan is for extra push.
We actually found that the 1:2 ratio lost enough in the belts to where it wasn't worth it.. so we're going with a 1:1 direct ratio.
The little turning axle running through the Igus pillow block was a testing stand to see what, if any gyroscopic forces would result from turning the prop.
And we're currently working to make sure we meet all the FIRST recommended specs on safety. IE you can't stick a finger in the mesh, and if you can it won't go far enough in to get hit by the blade. We'll do some measurements tomorrow to find out if we need to make a deep dish pizza pan.
I'll post a final picture of the conveyor system/ fan o' doom after build season ends. Let's just say.. it looks decently scary at this point.
-Greg
Unread 10-02-2009, 22:01
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
or shot your eye out
Yes it's nice to joke about that, but that prop spinning at 3000pm (those are CIM's right), with what looks like at least a 2:1 step up which give you 6000rpm, or 100 rps (revolution per second), and lets say its about a one foot in diameter so it moves at about 100 fps (100 fps= 68.18 mph)
So it should be secured...
Is now an engineer thanks to FIRST.
Unread 10-02-2009, 22:04
EricH EricH is offline
Take it easy, guys. They've already posted their protection. http://www.chiefdelphi.com/forums/sh...&highlight=665
Though I think that cake dish may need to be deeper.
Team 665 Fan/s and More Greg Peshek Robot Showcase 63 29-03-2009 14:00
pic: Team 8's Odin, ready to go danshaffer Robot Showcase 1 19-02-2008 11:43
pic: Team 665 REAL Chassis, Kinda-Teaser Greg Peshek Extra Discussion 13 25-01-2008 08:14
Team 665 TheFuhr Robot Showcase 13 23-01-2008 13:04
pic: Dave's Fan Club Alex Burman Extra Discussion 4 11-12-2006 21:59
