Go to Post If the left side of your brain controls the right side of your body then left handers are the only ones in "their right mind". - Al Skierkiewicz [more]
Unread 09-02-2009, 10:04
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
pic: Team #379's Teaser #1
Unread 09-02-2009, 10:06
powerkane's Avatar
powerkane powerkane is offline
AKA: Earl Colter
FRC #0858 (Delphi Demons)
powerkane is an unknown quantity at this point
Send a message via MSN to powerkane
Re: pic: Team #379's Teaser #1
it looks like you are going to use that wheel as a shooter?
Unread 09-02-2009, 10:18
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Also the output shaft appears to be a half inch, keyed shaft with a 1/4-20 tapped hole in the end. I wonder who sells those shafts.....
Collin Fultz
Unread 09-02-2009, 18:38
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Okay, you win, your flywheel is bigger. But ours is mostly encased in bullet-proof glass, so hopefully it won't explode into someone like it did last week...
pic: 379's test chassis and trailor on FRP Hadi379 Extra Discussion 22 22-01-2009 20:41
Team 379's Website Hadi379 Website Design/Showcase 3 15-02-2008 23:26
pic: 379's transmission Robo_Cat_379 Extra Discussion 10 05-03-2007 08:48
pic: 379's 2006 Robot Cat 7 Robocat1 Robot Showcase 16 05-03-2006 12:20
pic: 1141 gets under 379's skin CD47-Bot Extra Discussion 2 06-04-2004 09:27
