Go to Post Support an awesome scholarship fund for deserving students by buying sweet CAH expansion packs? Heck yeah. - Cothron Theiss [more]
Unread 09-02-2009, 20:06
ttldomination's Avatar
Sunny
Re: pic: FRC1293's Power Dumper [With video bonus!]
Wow...Well...I hope we're with yall and not against yall at palmetto. See yall then.
1648: 2013-2014
5283: 2015
Unread 09-02-2009, 21:48
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Do you have a method to "compact" the balls you store? It looks like all the rollers are powered by one belt.
Queen's Applied Science '13, Applied Mathematics
Unread 09-02-2009, 21:59
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Actually we can hold around 12-16 without compacting. It wasn't our goal to compact. Also yes all of the rollers are powered by 1 chain. The chain just goes from the inside of one sprocket to the outside of another on the way up causing the rollers to go in opposite directions for each other. So far the design is working really really well.
We plan on adding either an optical or sonar type sensor on the intake rollers to ONLY run our manipulator rollers when a ball is picked up to prevent our rollers from running excessively and possibly tearing up the balls.
Unread 10-02-2009, 07:06
President, VEX Robotics, Inc.
I have a stupid question:
How wide are your front two small pieces of drive base? Scaling from the wheel size, it looks like they are only 3 or 4 inches long. How wide will your plywood backing for the bumpers be at those front two spots? Another way to put it is, how wide is your ball intake at the ground?
Paul
Unread 10-02-2009, 07:23
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
FYI - a 6" bumper plywood backing attached to a 3" metal bar will not pass inspection since it's not supported along its entire length. For example, with a rectangular robot that is the max 28"x38", the opening can be, at most, the length of the edge minus 12". You can build a build that fits in the 28"x38" sizing box at a slight angle and use a marginally larger opening but you'd be building a very thin robot.
If Paul is right and your leading edges are small, the inspectors will give you a hard time and probably ask you to modify your chassis.
Better now than in 2.5 weeks.
Russ Beavis
Chief Inspector
Unread 10-02-2009, 12:25
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
Our bumpers are 5" wide each at the front, but to make ourselves legal we're bolting a 1' or so long piece of 1010 sized 8020 to the inside of the wheel assemblies giving us another inch on each side.
They look 3-4 inches long only because our flanges bend inwards on the drivetrain sideplates.
pic: FRC1293's First OFFICIAL teaser Thermal Extra Discussion 5 14-01-2009 23:08
[Video] Robot Power by NI Control @ IRI Josh Hambright FRC Control System 3 02-08-2008 16:14
pic: Who is this? Bonus question- who's hat is it? Rosiebotboss Extra Discussion 18 21-04-2007 19:07
pic: Team 378 lifts 1249 & 128 for 60 point bonus in Pittsburgh demps45 Extra Discussion 4 14-03-2007 20:36
pic: new dumper supersy77 Robot Showcase 2 11-04-2005 15:17
