Go to Post If a team wants to cheat then it does nothing but give them a bad cloud hanging over their own heads. - Jon K. [more]
Unread 08-02-2009, 21:37
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Re: pic: Ungreased toughboxes!!!!
Originally Posted by squirrel View Post
Part of the kit. Didn't you at least look at the kit gearboxes?
obviously not. using something different ...
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
Unread 08-02-2009, 21:38
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
sort of like not reading a manual and just throwing it out when you open the box
Unread 08-02-2009, 22:43
cbale2000's Avatar
AKA: Chris Bale
FRC #5712 (Gray Matter)
So THAT'S why our gearboxes keep doing that.......
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 08-02-2009, 23:47
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
Well to answer a few questions, the gearboxes ran for about 10 hours each on the playing surface using the rover wheels. In the rush to make the practice and chase (rabbit) robots the greasing completely slipped my mind and thus the result. Unfortunately this had happened all 4 of the gearboxes. On the final robot we did grease it but this was before we saw this problem. After seeing what happened I m going to go back and ultra lube it. Assembly wise I m quite sure they were aligned properly and there were no mistakes there.
Unread 08-02-2009, 23:54
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Everything happens fast in FIRST and Shift happens. Have fun and hope to see you at nationals.
R.C.
MadTown Robotics Team 1323
Unread 09-02-2009, 09:32
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
From the picture it looks like you have a custom output shaft, 3/8 hex with 3/8 bearings on both ends. Also the gear on the CIM looks like minimal to no damage. From this I would check your center distance for the final reduction. Too tight and lack of lube may be a combination that caused your failure.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 09-02-2009, 12:24
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
This reminds me of a true story:
A farmer brought a worn-out guage wheel assembly to my uncles machine shop. The farmer turned to his own son and said "See that's what happens when you grease it too much". The son quickly responded "Oh no papa - I never greased that thing!".
Brian K
Team 1225 Robotics Mentor
Unread 09-02-2009, 17:27
dtengineering's Avatar
AKA: Jason Brett
Well to answer a few questions, the gearboxes ran for about 10 hours each on the playing surface using the rover wheels. ...
I have to admit I was intially quite reluctant to believe that a lack of grease alone would cause such catastrophic failure in a Toughbox... after all, we just dab a bit of white lithium grease on there and have never had a problem. But I doubt that even our last year's gearboxes have seen ten hours of continuous driving.
I find that even with the wheels up and off the ground and just the drag of the gearbox and chains, the CIM draws just under three amps and needs to be cooled after 20 minutes or so of continuous use. With the robot on the ground and driving, I wouldn't rate the CIMs at even a 50% duty cycle. This means that based on my experience, ten hours of continuous practice driving is going to require somewhere in the neighbourhood of 20 hours at a practice facility at a minimum. I doubt we have ever had more than an hour or two of actual driving time on our toughboxes before we ship, including a 20 or 30 minute "break in" period that we give each gearbox. (Yeah, I know the gearboxes shouldn't "need" to be broken in, but we find that the drive system as a whole seems to run smoother and at a lower current draw after it has been spun around a few thousand times.)
Given that a regional involves, say, 12 two and a half minute matches (admittedly some teams have a slightly higher average...), and assuming an equal time spent practicing on the practice fields, it would be unlikely for a toughbox to see much more than an hour's use at any given competition.
So I guess what I'm getting at is that 10 hours of actual driving under load is actually a pretty good lifetime for a Toughbox, particularly one without grease. With grease, it would be reasonable to assume a lifetime greatly in excess of ten hours, making them, for all practical FRC purposes, eternal.
Thanks for posting that crucial piece of information about time to failure... I had been assuming this was a new gearbox, freshly assembled, that had failed in less than an hour of use and that just didn't seem to make sense, grease or not.
Jason
Unread 09-02-2009, 18:25
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Jason,
We've been really "lucky" this year to have had a lot of time to drive on the playing surface so far during build season.
We assembled the C-Base kit-frame the day we received it, and have also had our practice robot assembled for some time now. Between the two robots, we've had about 4 weeks of continuous driving. Many nights we have both robots going at the same time, and in a few days we'll have all three on the field.
The blessing is that we've had more time driving during a build season than I've ever witnessed. The drawback, is that as we play with traction control, and test over longer periods of time, failures tend to happen.
However, besides blowing a few Jaguars, and having this happen, it's been a pretty uneventful build season =)...
I guess take this as a public service announcement:
Grease your ToughBoxes!
Be nice to your Jaguars!
If there's any advice I'd give from Team 188 to other teams, it would be that.
Even though we expected the low-friction environment would be "easier" on our drive components, we've quickly found out that this may be the most taxing year we've ever witnessed on a drivetrain in FRC.
Unread 09-02-2009, 21:36
AKA: Dani
well i just thought that this was all common sense, but if not. Yes grease your gear boxes, and dont be cheap!
Grease doesn't cost that much, so put lots on lol...
Unread 09-02-2009, 22:49
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Thanks to these guys for reminding teams that grease is good to use.
We saw this situation a few times last year at events. Each time, no grease was used. In the future, maybe we should include a little packet of grease for each gearbox.
New gears are packed up and ready to ship up to Canada tomorrow. You guys should get this shipment on Wednesday (if all goes well crossing the border).
Sincerely,
Andy Baker
Unread 09-02-2009, 22:52
AKA: Dani
nice, and yea or maybe a warning sticker saying this?
anything would do...
Unread 09-02-2009, 23:20
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
ya you sould realy grease up those tyrannies... lol
Curie..
Unread 09-02-2009, 23:32
MrForbes MrForbes is offline
My thoughts exactly...
A lot of people who build robots don't seem to know that grease is required, so anything you can do to ensure the gearboxes are greased would be a good thing. I encountered two experienced teams last year who lost gears in competition due to no grease!
Unread 10-02-2009, 00:33
R.C.'s Avatar
We just put a crap load of grease on our 5 special gearboxes, we use lithium grease if anyone wants to know and it works extremely well.
R.C.
