Go to Post You do realize that you all started jumping to conclusions without asking first which JVN he was talking about. - Jay H 237 [more]
Unread 10-02-2009, 01:45
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: GUS Team 228's 2009 Robot Render
After just finishing several more renders, it appears I forgot to set some of the components in PhotoWorks, like the front chassis rail and the timing belt sprockets. Anyway, a different angle of the front of the robot.
P.S. Does anyone know a really good way to run real roller chain in SolidWorks (especially with different size sprockets)? I know you can do linear and circular patterns, but it's just so much easier to make a belt-like loop and override the mass properties to the correct weight (#25 pitch chain is .090 lbs/ft). I'll switch to real chain if an easy way exists.
Originally Posted by rc_cola1323 View Post
Loving the Sick Render Art and whatz the weight, looks macho heavy senor.
We did a weigh-in of the practice robot (which is a lot more complete than our competition robot, as we send the practice robot to the Suffield Scrimmage) with most of the control system mounted (including CRIO, PD Board, Side Car, 2 Jags and 4 Victors) and the pneumatics compressor and two accumulators. We also put an entire 4'x8' sheet of polycarbonate to simulate the panels we have yet to cut out. We were missing some parts from the robot, but no more than about 10 pounds worth.
When we weighed in, we were at 99.5 pounds. Adding the other ten pounds of parts still to be installed, and we're still ten under. And the mounting for everything weighs almost nothing, as we're using 1/16" polycarbonate with 3/4" x 3/4" x 0.050"-wall aluminum angle with lots of rivets for making everything. Incredibly lightweight and strong.
Art Dutra IV
世上无难事,只怕有心人.
pic: 228's Completed Robot artdutra04 Extra Discussion 15 05-04-2009 18:34
pic: GUS Team 228's 2009 Teaser #1 artdutra04 Extra Discussion 9 03-02-2009 13:31
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
pic: GUS Team 228's 'Drive-by' Autonomous artdutra04 Extra Discussion 4 23-05-2007 20:11
Introducing: GUS Team 228's 2007 Website! artdutra04 Website Design/Showcase 18 20-03-2007 19:46
