Re: pic: FRC1293's Power Dumper [With video bonus!]
I have a stupid question:
How wide are your front two small pieces of drive base? Scaling from the wheel size, it looks like they are only 3 or 4 inches long. How wide will your plywood backing for the bumpers be at those front two spots? Another way to put it is, how wide is your ball intake at the ground? Paul |
FYI - a 6" bumper plywood backing attached to a 3" metal bar will not pass inspection since it's not supported along its entire length. For example, with a rectangular robot that is the max 28"x38", the opening can be, at most, the length of the edge minus 12". You can build a build that fits in the 28"x38" sizing box at a slight angle and use a marginally larger opening but you'd be building a very thin robot.
If Paul is right and your leading edges are small, the inspectors will give you a hard time and probably ask you to modify your chassis. Better now than in 2.5 weeks. Russ Beavis Chief Inspector |
Our bumpers are 5" wide each at the front, but to make ourselves legal we're bolting a 1' or so long piece of 1010 sized 8020 to the inside of the wheel assemblies giving us another inch on each side.
They look 3-4 inches long only because our flanges bend inwards on the drivetrain sideplates. |
| pic: FRC1293's First OFFICIAL teaser | Thermal | Extra Discussion | 5 | 14-01-2009 23:08 |
| [Video] Robot Power by NI Control @ IRI | Josh Hambright | FRC Control System | 3 | 02-08-2008 16:14 |
| pic: Who is this? Bonus question- who's hat is it? | Rosiebotboss | Extra Discussion | 18 | 21-04-2007 19:07 |
| pic: Team 378 lifts 1249 & 128 for 60 point bonus in Pittsburgh | demps45 | Extra Discussion | 4 | 14-03-2007 20:36 |
| pic: new dumper | supersy77 | Robot Showcase | 2 | 11-04-2005 15:17 |
