Go to Post That's one of the saddest stories I've ever heard. When your green isn't neon enough, you are in big trouble in FIRST. - JaneYoung [more]
Unread 10-02-2009, 07:23
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: pic: FRC1293's Power Dumper [With video bonus!]
FYI - a 6" bumper plywood backing attached to a 3" metal bar will not pass inspection since it's not supported along its entire length. For example, with a rectangular robot that is the max 28"x38", the opening can be, at most, the length of the edge minus 12". You can build a build that fits in the 28"x38" sizing box at a slight angle and use a marginally larger opening but you'd be building a very thin robot.
If Paul is right and your leading edges are small, the inspectors will give you a hard time and probably ask you to modify your chassis.
Better now than in 2.5 weeks.
Russ Beavis
Chief Inspector
Unread 10-02-2009, 12:25
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Our bumpers are 5" wide each at the front, but to make ourselves legal we're bolting a 1' or so long piece of 1010 sized 8020 to the inside of the wheel assemblies giving us another inch on each side.
They look 3-4 inches long only because our flanges bend inwards on the drivetrain sideplates.
pic: FRC1293's First OFFICIAL teaser Thermal Extra Discussion 5 14-01-2009 23:08
[Video] Robot Power by NI Control @ IRI Josh Hambright FRC Control System 3 02-08-2008 16:14
pic: Who is this? Bonus question- who's hat is it? Rosiebotboss Extra Discussion 18 21-04-2007 19:07
pic: Team 378 lifts 1249 & 128 for 60 point bonus in Pittsburgh demps45 Extra Discussion 4 14-03-2007 20:36
pic: new dumper supersy77 Robot Showcase 2 11-04-2005 15:17
