Go to Post Isn't the professional level for us called a job? - CalTran [more]
Unread 18-02-2009, 19:10
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: pic: 1429 New Crate
Are you sure you got the weight right, if so how thick is the aluminum. The density of aluminum is about 0.1 lb/cu.in. It’s not clear how tall it is but I’ll assume 5’ (60”) for the box and 4’ (48”) on each side. That’s 4 x 48 x 60 = 11,520 sq.in. for the sides plus 2 x 48 x 48 = 4608 sq.in. for the top and bottom. Divide 90 lb by 0.1 lb/cu.in. and again by (11,520 + 4608) sq.in. and you get an average thickness of a little less than 1/16”. That’s without skids, connections or internal bracing. That is NOT going to made for a very robust crate.
Jason
pic: 987's New Crate KF987 Extra Discussion 12 22-01-2009 18:11
pic: Team 1429 Regional Chairman's award Pjohn1959 Extra Discussion 8 10-03-2008 13:50
pic: Team 1429 Robot Pjohn1959 Extra Discussion 3 04-03-2008 09:51
pic: Team 1429 in action Pjohn1959 Extra Discussion 1 09-03-2007 00:04
pic: 1429 Ramps deployed Pjohn1959 Robot Showcase 11 15-02-2007 15:09
