Go to Post Team 233 cannot wait for the Florida Regional, but they have to because they have to build a robot or something first. . . - IbleedPink233 [more]
Unread 22-02-2009, 21:06
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Re: pic: Team 2423's robot pic1
Nice looking frame, very interesting choice of materials, I do believe this is the first time I've seen a frame built like that. Just wondering, is it steel or alu tube? Also, what OD/wall?
Are you also using a belt-driven steering system?
It looks very nice. I'm assuming there's some upper assembly that's not in this picture. Good luck this year!
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 22-02-2009, 21:14
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Impressive Drivetrain. Did you guys pocket out the gears or did you guys use aluminum gears?
R.C.
MadTown Robotics Team 1323
Unread 23-02-2009, 00:52
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
I'm pretty sure we use aluminum, but I'll have to check to be sure.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 23-02-2009, 00:49
FRC #2423 (KwarQs)
Ahh... I didn't realize that when you upload a picture it becomes its own thread... that means there are 3 threads with the same picture floating around here. My bad.
As the most I've done with this frame was look at the designs and the finished product, I'm not really the one to give you the specs. I'll be sure to ask, though.
The gear/whatever that rotates the wheel is belt-driven. I think a shaft with a gear head runs through it powering the wheel the moves the bot.
KwarQs 2423
Team 2423's Robot AmoryG Robot Showcase 1 17-02-2009 10:13
pic: Team 469's Robot for 2006 pic 2 Don Wright Robot Showcase 10 26-02-2006 21:03
pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! sgsdragons Robot Showcase 4 01-03-2005 16:21
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
