Go to Post JVN, Captain Mechanical Engineer, Mr. "Software is evil", has supported the CMU camera. I'm speechless. What's next? Copioli designing in imperial? - Karthik [more]
Unread 23-02-2009, 00:49
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Re: pic: Team 2423's robot pic1
Originally Posted by Lostmage333 View Post
Nice looking frame, very interesting choice of materials, I do believe this is the first time I've seen a frame built like that. Just wondering, is it steel or alu tube? Also, what OD/wall?
Are you also using a belt-driven steering system?
It looks very nice. I'm assuming there's some upper assembly that's not in this picture. Good luck this year!
Ahh... I didn't realize that when you upload a picture it becomes its own thread... that means there are 3 threads with the same picture floating around here. My bad.
As the most I've done with this frame was look at the designs and the finished product, I'm not really the one to give you the specs. I'll be sure to ask, though.
The gear/whatever that rotates the wheel is belt-driven. I think a shaft with a gear head runs through it powering the wheel the moves the bot.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Team 2423's Robot AmoryG Robot Showcase 1 17-02-2009 10:13
pic: Team 469's Robot for 2006 pic 2 Don Wright Robot Showcase 10 26-02-2006 21:03
pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! sgsdragons Robot Showcase 4 01-03-2005 16:21
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
