Go to Post This is how students can be inspired! - Rich Wong [more]
Unread 26-02-2009, 22:38
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: Macbooks aren't the only Unibody Construction
Very nice gearboxes, compact and simple. I'm a little confused though... Isn't your robot finished already? Are these upgrade parts, or perhaps for another team?
A robot is never truly finished - there's always something that can be upgraded, something that to be designed better, faster, stronger.
In this case, these transmissions are going to replace two Globe motors currently powering our polycord elevator which brings balls up to the shooter. Don't get me wrong, the Globe motor powered elevator works just fine right now without any problems, but we can only fire about 2.5 balls/sec right now. With these new transmissions powered by a single FP motor, we'll be able to get 8-10 balls per second to our shooter, with a net change in robot weight of -0.9 pounds.
The three gearboxes include one for competition robot, one for practice robot, and one for a spare that will probably be assembled with a Lexan (as opposed to aluminum) cover to have in the pits to show people. The gears used in the transmission are from the first two stages in the KoP FP gearbox. I couldn't think of an elegant way to mount one of the KoP FP transmissions while outputting through the second cluster shaft with a cantilevered load, hence the design of this.
Previous revision: (on almost completed practice robot)
New revision:
And the outer plate (the pockets are on the inside of final assembly)
Art Dutra IV
世上无难事,只怕有心人.
Unibody/Monocoque Construction Sam N. Technical Discussion 26 18-06-2007 15:09
pic: This is what happens when the parts aren't in. RoboDriver1718 General Forum 4 23-01-2007 09:03
pic: The only two Poof balls left in NH.... Andy Grady Extra Discussion 9 09-01-2006 07:36
pic: And it's only the first day... CD47-Bot Chit-Chat 8 17-01-2004 20:21
Aren't you tired of seeing this woman? Joe Johnson General Forum 30 18-01-2002 12:40
