Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
  #36   Spotlight this post!
Unread 03-03-2009, 02:02
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
Re: pic: Skunkswerve Module Cross Section
We used rotary encoders (non-absolute) to close a position loop around our steering motors. Our modules can twist in any one direction indefinitely.
To align our wheels upon robot enable (to tell software where "forward" is so we can measure displacement from zero) we use a pair of IR emitters/optical sensors. The wheels automatically snap forward (it takes .5 seconds) and then normal operation begins.
It's not the best solution... two separate sensors + wiring and a pre-operation software routine, but it works.
Mitty Robotics Alumni
TKO 1351
pic: Skunkswerve....team 1983 Bob Steele Extra Discussion 22 30-01-2009 22:09
pic: Rage 173 cross section of robot in SolidWorks TriggsJr Extra Discussion 20 05-05-2005 10:58
Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 BookerT Programming 13 27-01-2005 09:49
Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 BookerT Programming 0 25-01-2005 19:17
