Go to Post Admiration is universal, it does not exclude those who have achieved past success. - hg273 [more]
Unread 03-03-2009, 21:54
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: pic: Macbooks aren't the only Unibody Construction
Originally Posted by artdutra04 View Post
The gears used in the transmission are from the first two stages in the KoP FP gearbox. I couldn't think of an elegant way to mount one of the KoP FP transmissions while outputting through the second cluster shaft with a cantilevered load, hence the design of this.
First, let me say your gearbox is really cool! If we had that kind of machining capabilities in-house we'd probably do the same. Since we don't, and value our sponsor's precious machine time, this is what we came up with (which is why I asked this) - not sure you'd consider it elegant, but it sure worked
The last stage of the gearbox was removed, the case was reduced to acomodate only two stages and dremeled to pass the chain through. That way, the shaft which supports the second stage gears (and now this sprocket as well) is fully supported, not cantilevered.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unibody/Monocoque Construction Sam N. Technical Discussion 26 18-06-2007 15:09
pic: This is what happens when the parts aren't in. RoboDriver1718 General Forum 4 23-01-2007 09:03
pic: The only two Poof balls left in NH.... Andy Grady Extra Discussion 9 09-01-2006 07:36
pic: And it's only the first day... CD47-Bot Chit-Chat 8 17-01-2004 20:21
Aren't you tired of seeing this woman? Joe Johnson General Forum 30 18-01-2002 12:40
