Re: pic: FRC-34 2009 Swerve Module w/FP (Side View)
WOW. diggin the detailed shots! this is really clean and well thought out! These do look similar to the 111 swerve that works so well. do your delrin plates simply sandwich the bottom circle? if so, what does that little block on the edge do?
although it looks machining heavy, i can see the benefit of the weld less chassis, no doubt what that repeated hole pattern is for. good work *edit: OH MY, there are so many andy-mark parts here! the sprocket, the gears, the axle, the encoder, the bearings. wow! **edit: OH MY, and your coming to Lone Star, OH BOY!!! Last edited by roboticWanderor : 09-03-2009 at 02:11. |
There's also two AM 500 Hubs and two of the short hex shafts. The little block on the bottom prevents an "Out of control" module from spinning more than 320 or so degrees. It interferes with another plate on the bottom bearing (not shown). I'll post an exploded view of the whole thing after we get back from Peachtree.
| pic: 1346 Side View 2009 | dtengineering | Extra Discussion | 8 | 05-02-2009 15:23 |
| pic: FRC 1771 Swerve Module | sdcantrell56 | Extra Discussion | 17 | 13-04-2008 00:36 |
| pic: stangs swerve module | Aren_Hill | Extra Discussion | 8 | 23-04-2007 08:15 |
| pic: Swerve! (Module) | =Martin=Taylor= | Extra Discussion | 13 | 09-07-2006 19:57 |
