Go to Post We can't be afraid to critique the existing system. If we don't, how will it ever get better? - Jaine Perotti [more]
Unread 03-11-2009, 11:17 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
pic: BeachBot Pseudo-Crab drive, partially assembled
Unread 03-11-2009, 11:18 PM
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: BeachBot Pseudo-Crab drive, partially assembled
Wow, so thats what it looks like.
If all else fails does it drive like a normal 6WD?
-Dustin Benedict
Unread 03-11-2009, 11:33 PM
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
ooooohhhhhhhh, can't wait to see it perform in a couple of days ;>
Unread 03-11-2009, 11:36 PM
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
How much is the center wheel lowered? Related: how much does the front rock up and down?
How are you controlling it? (I'd probably use a standard arcade joystick and the x axis of a second joystick to set the angle to rotate the drive base)
Great job as always, cant wait to see how it handles on the crater with a trailer, I bet you could have the best "spin auto" in the game. Too bad I didnt get to see it in person at, guess I'll have to wait for Champs!
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 03-12-2009, 12:11 AM
swamp_child's Avatar
swamp_child swamp_child is offline
AKA: Cody
FRC #0179 (Children Of The Swamp)
swamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to all
you guys are going to win a ton of awards with that
2009 Florida Champions thanks to 233 and 1649!
2008 UCF finalists thanks to 69 and 342
2007 world Finalist, thanks to 233 and 71, we love you guys
2007 Archemedies undefeated champions, thanks to 233 and 71
2007 UCF finalists thanks to 1902 108 and 386
Unread 03-12-2009, 03:02 AM
ShaneP's Avatar
ShaneP ShaneP is offline
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
Yes. The turntable is powered by a BaneBot 545 motor in a 64:1 planetary gearbox, which is not easily back driven. If we do not power the 545 motor, the robot drives like a standard 6 wheel drive robot. We noticed that turning ability was somewhere in between a narrow and wide configuration, but closer the narrow configuration.
The center wheel is lowered 1/16th of an inch.
We are controlling the drive with a steering wheel and one joystick. The steering wheel controls the powered turntable, and the joystick is in arcade mode, controlling the drive like a normal 6 wheel drive.
Here's more info on how it works: http://www.chiefdelphi.com/forums/sh...5&postcount=15
Unread 03-12-2009, 08:38 AM
Rookie Year: 1997
We tried many different methods of controlling it, and what you described is what we ended up with, except using a steering wheel instead of a standard joystick. We also tried a joystick with a Z axis, and several methods of trying to keep the trailer stationary while turning the base, but never got those fully tweaked. If we ever turn into a defensive robot, we might bring one of those back, since it makes driving really easy, as long as you don't have to keeep the front aligned.
We do have a spin auto mode, but didn't have enough regolith to fully test it. It's not that huge of an advantage though for a spin auto mode. We can make the robot spin around the trailer very easy, but that leaves the trailer in one place to get filled up. For actually moving the trailer, we're not any better then a normal robot. We have other plans for auto, though, so I'm not sure we'll ever use it.
Unread 03-12-2009, 10:41 AM
President, VEX Robotics, Inc.
Team 330,
This is an interesting design. I don't want to be a rules miser or anything, but don't you technically have a robot that is turreted and the bumpers move with respect to the drive base. We specifically ruled out doing something like this because the frame that the motors and gearboxes are connected to is technically your fixed drive base. The top structure is a turret that moving. Don't get mne wrong, I love the design but how is this not considered a turret? Just becasue you put the bumpers on it? I hope that there is not an overzealous inspector that rules against this design. I wouldn't, but I know some that would ....
I'm just looking out for my friends in Southern California.
Paul
Unread 03-12-2009, 11:07 AM
Jared Russell's Avatar
Taking a year (mostly) off
Originally Posted by Paul Copioli View Post
Team 330,
Paul
The earth doesn't revolve around the sun; the sun revolves around Paul Copioli.
(In all seriousness, to my knowledge the rules don't ever specify that the bumpers and trailer hitch must be stationary relative to any particular reference frame).
Unread 03-12-2009, 04:11 PM
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It shouldn't matter: the rules say where the bumpers should be with respect to the entire robot (i.e. in the bumper zone, on the perimeter). What happens inside the robot, or where its drivetrain is located, doesn't affect anything.
It's popular to define the robot frame as "the thing that holds the wheels", but the rules make no such definition. (A similar situation came into play last year, with 1519's dual-configuration robot/two robots. It was ruled that because the main structure of the robot was being interchanged, that it was actually two robots...the trouble was, there was nothing in the rules to define the main structure.)
Unread 03-12-2009, 04:58 PM
Data Nerd
FRC #0079
Team 330,
Paul
I can't see an inspector ruling this out, in reality it is like any other crab drive, the wheels rotate and the base stays in a fixed location. The sole difference is that instead of a single wheel rotating 6 of them are.
Just my $.02
Unread 03-12-2009, 05:06 PM
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
Team 330,
Paul
I would think that this is not dissimilar to any drive train that has independently steered wheels.... so which wheel in our swerve is the robot? they all move independently and you could loosely say we have a turret design too...
I would think that the robot...for this game.... could be defined as whatever attaches directly to the trailer...
I hope you guys do well.... and we hope to see you in Atlanta again..
R
Unread 03-12-2009, 05:49 PM
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I think I understand where Paul is coming from; we had the idea at the beginning of build season to attach the bumpers and trailer hitch on a turntable so they could be moved relative to the rest of the robot, but threw it out because of rule R18.B:
Originally Posted by <R18> B
The Trailer Hitch must be rigidly attached to a fixed location on the ROBOT, with the long dimension of the Trailer Hitch horizontal and the opening of the C-channel facing away from the ROBOT. The horizontal center line of the Trailer Hitch must be 2-13/16 inches above the floor, +/- 0.25 inches.
It seemed obvious to us at the time that the design would not pass inspection... based on the logic we were using at the time, 330's design is questionable, as is any robot with a swerve drive to some degree. It's kind of a hazy subject that will be left open to the inspector's interpretation.
I certainly hope there are no inspection issues though... it's a cool design!
Unread 03-12-2009, 06:12 PM
Bob Steele's Avatar
AKA: Bob Steele
I am curious to find out why you would think that the Beachbot's design does not comply with this rule?
"The trailer hitch is rigidly attached to a fixed location on the robot."
In their design this is true...for it not to be true you would have to have a non-fixed location or a location that is changing on the robot.
Just because the wheels turn under the frame does not make this false..
If one were to define "fixed location" on the robot in the way it is apparently being discussed.... you would have to have NO moving parts on the robot at all...
Relative motion is relative motion...
What is moving? One can only define that when one picks a frame (no pun intended) of reference. The Beachbots have chosen to use their outer frame as that frame. It is fixed... the wheels rotate below it...rigid attachment and fixed location... sounds ok to me...
I would be happy to argue this rule with an inspector...
(I am a physicist so frames of reference come naturally to me...)
Unread 03-12-2009, 08:52 PM
Cascade Cascade is offline
Intermittent Mentor
Cascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to behold
The only rule that seems to apply is R6. Since the wheels can only be rotating in the direction 330 will be moving, no problem.
330 has proven once again why they are a perennial powerhouse: out of the box thinking, design, and something that advances FIRST.
Well done. Can’t wait to see this in Vegas.
pic: 1771 crab drive sdcantrell56 Extra Discussion 9 06-29-2008 12:02 AM
pic: Crab Drive Frame evanisthat! Extra Discussion 15 12-19-2007 08:04 PM
pic: Ultimate Vex crab drive 2 cire Extra Discussion 9 06-01-2007 04:46 PM
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 06-21-2006 04:03 PM
pic: Crab Drive Joe_Widen Extra Discussion 3 04-23-2006 03:49 PM
