Go to Post I'd rather have a bot in front of me than a frontal lobotomy. - Neal Probert [more]
Unread 15-03-2009, 22:53
klrswift klrswift is offline
AKA: Kevin Swift
FRC #0910 (Foley Freeze)
klrswift has a spectacular aura aboutklrswift has a spectacular aura aboutklrswift has a spectacular aura about
Send a message via AIM to klrswift
Re: pic: The chances we take!
We have a little saying on our team.
"Don't worry, we'll fix it in software."
Unread 15-03-2009, 23:06
Stuart's Avatar
Stuart Stuart is online now
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
OK so plus 10 points for style, but minus several million for intelligence . .
but I do like the cable management job you did, very spiffy.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 16-03-2009, 00:39
Justin_B's Avatar
Justin_B Justin_B is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
Justin_B is an unknown quantity at this point
there is a good lesson to be learned here, measure twice, cut once, or something like that. And why didn't you cover the electronics, to prevent the dust from getting in. we had to do some similar modifications to our electronics board also, but that was because we forgot to mount a speed controller.
Unread 16-03-2009, 00:44
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
we did shave off from the opposite side as far as we could. also though, We did blow the whole thing off with compressed air for about 10 minutes and made sure to check for any shavings in the system before powering up. It was kind of getting crunch time when we did this, but we did take as much caution as possible while doing it... (should of thought of covering the crio ports though... oops )
Unread 16-03-2009, 00:55
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Dear god is there no other way other than to put that cRIO that close to the saw blade? Your electronics captain must have had a heart attack, and even after being revived had another one.
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Unread 16-03-2009, 00:57
AKA: Samir Shaikh
FRC #4329
lol... the angle kinda makes it look closer than it is. Once we got that close, we had backed it out and then we used a dremel tool. we had about 4 people guiding it through and watching it very closely..
and if you notice, the blade could not touch it because it's guard was just above the lexan so nothing besides the lexan could touch the blade.
Unread 16-03-2009, 08:29
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
This is a joke, right?
Right?
It better be a joke. Two screws and two small cables, all easily removed, are the only things connecting the cRIO to the panel. Keeping the cRIO there and totally unprotected while running it through a band saw is, to put it bluntly, stupid.
Unread 16-03-2009, 10:33
EricVanWyk EricVanWyk is online now
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Right?
I deleted a similar post draft of mine because I couldn't find a polite way to say it. Don't do this. This is why we have to label coffee as hot.
Unread 16-03-2009, 12:24
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Lol the sawdust can't be too good for the connections. You should've removed the cRio first.
pic: The Referees gang up to make us take them off kevin.fort Extra Discussion 1 28-03-2007 10:17
Take some time, read the manual, take a breather, and calm down. Elgin Clock General Forum 8 08-01-2006 18:35
Tips to increase your chances of winning an award at the nationals thoughtful Championship Event 4 03-04-2005 16:32
What speed do you surf the net? Take the test! Elgin Clock IT / Communications 77 30-03-2005 16:28
Chances at UTI Matt Attallah Career 0 28-01-2003 20:20
