Go to Post Because the new control system weights as much as a fully-loaded M1 Abrams Tank. - artdutra04 [more]
Unread 16-03-2009, 00:44
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: pic: The chances we take!
we did shave off from the opposite side as far as we could. also though, We did blow the whole thing off with compressed air for about 10 minutes and made sure to check for any shavings in the system before powering up. It was kind of getting crunch time when we did this, but we did take as much caution as possible while doing it... (should of thought of covering the crio ports though... oops )
pic: The Referees gang up to make us take them off kevin.fort Extra Discussion 1 28-03-2007 10:17
Take some time, read the manual, take a breather, and calm down. Elgin Clock General Forum 8 08-01-2006 18:35
Tips to increase your chances of winning an award at the nationals thoughtful Championship Event 4 03-04-2005 16:32
What speed do you surf the net? Take the test! Elgin Clock IT / Communications 77 30-03-2005 16:28
Chances at UTI Matt Attallah Career 0 28-01-2003 20:20
