Go to Post Pessimism and optimism are both contagious. - Taylor [more]
Unread 17-03-2009, 20:46
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
FRC #0706 (Cyberhawks)
reversed_rocker is on a distinguished road
Re: pic: T-Shirt Launcher, still needs a chasis
alright i'll try to answer the questions in the order they arrived:
1.The revolver hasnt caused any leaking, the chambers are slightly smaller than the barrel itself and are mounted to a single piece of acrylic. Also, the parts were all CNCed so they fit together extremely well. Theres a switch at the bottom of the revolver that will stops it each time a new chamber is lined up. Since the chambers are cylindrical, the switch will only trigger at the absolute lowest point on the chamber (which also happens to be the center).
2. We used all pressure rated PVC and never let it get above 60 psi, no matter how much we want to . I know where you're coming from tho, using PVC gave me the jitters at first
3. I havent really timed how long it takes to fill with air... im guessing around 20 seconds? i'll see if i can get you a more proper estimate.
4. There are 3 motors on the cannon, one to rotate the base for aiming, one on a worm gear to change the launch angle, and finally one to rotate the revolver.
5.You can load tshirts in any chamber thats not in the barrel. You just shove the tshirt in any of the rotating chambers that you can get to. Normally the revolver spins only when the cannon is shot, but we also put a loading button on the joystick so we can cycle through the chambers to load them all. When we're firing, i mentioned the switch below the revolver earlier. After each shot, the revolver spins until the bottom of the chamber triggers the switch. If anyone's interested i can post the code
at the moment we have two chasis for consideration. We are either going to build a new chasis with tank treads or possible 6 wheel tank drive, or steal the chasis and crab drive from our lunacy bot (with much bigger off road tires of course) I for one am voting for the tank treads
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
FVC World Championship still needs volunteers! vavex Championship Event 0 18-03-2007 18:09
pic: Current Robot Chasis Pnakovich Robot Showcase 13 13-02-2007 17:55
