Go to Post During 5th week, EVERYTHING becomes a programming problem... hahah. - Mr. Lim [more]
Unread 23-03-2009, 10:04
Re: pic: Team 973 2009 Robot - RAPTOR
We initially trimmed them with dykes that were custom ground to have no back angle, but while being lazy I found that a table belt sander works great (not sure if fine grit is required, it's what we used and it worked great for us).
We're using our pneumatic tube cutters for our new belting when it comes in. The cutters work wonders in stopping pneumatic leaks, so we're hoping to get a clean cut on the Rounthane every time. We're using the tiny gator connectors for everything though, because we couldn't get welding to work during the build season .
GitHub
Unread 23-03-2009, 10:19
xAlLKnoWingOnex xAlLKnoWingOnex is offline
FRC #2219 (Megahurts)
Team Role: Operator
xAlLKnoWingOnex is an unknown quantity at this point
it looks amazing i wish i got to see it work in person
Unread 23-03-2009, 13:38
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
In 2006 we turned the rollers for our practice bot on a 13x40 lathe (fairly common size for any kind of school machine shop with lathes) without much difficulty.
As long as you have the travel it's not too hard to do it manually. Takes a long time though.
Making the grooves wasn't too hard for us, I was referring more to putting a 1" ID through the entire 26" tube, is there a way to do that too? I'm not a very skilled machinist at all, I just know enough to get by. Does 254 drill out the middle of their rollers?
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 23-03-2009, 15:07
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The rollers we made in 06 were out of thick wall PVC tube, so they had the bore through the middle already and we only had to bore an inch or two out larger at the end.
The problem with them was that PVC is extremely heavy, and each roller would have weighed around 7-8 lbs. We ended up having to get a shop to remake them out of ABS for the weight savings.
It's possible to drill a 1" through hole in the roller, if you drilled from both sides with a series of varying length drills, but that's obviously not an ideal solution.
2001-2004: Team 100
2006-Present: Team 254
Unread 23-03-2009, 16:57
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
but then how were the ABS roller's bores made then? it seems a long bore like that would be almost impossible in a flexible material like ABS
Unread 23-03-2009, 17:14
Cory's Avatar
AKA: Cory McBride
There's plenty of ways of doing it. In 06 the NASA model shop made our competition rollers. They turned them to the correct diameter/length/put the grooves in.
They did the boring in two different operations. They stood them up on end in a very large CNC mill and used a series of drills of increasing length to bore all the way through. After they had the through hole they put them in another CNC mill and contoured the larger counterbore for bearings/plugs on each end.
That's just one way of doing them. They can easily be done on the lathe with enough travel, or very accurately by someone who specializes in gundrilling. Our rollers this year were made for us by another sponsor who did everything on the lathe but the hexes on the ends, which they milled.
2001-2004: Team 100
Unread 23-03-2009, 18:42
The sponsor who made them specializes in all sorts of "tubing" and this really wasn't an issue at all for them. The lathes had several times the travel required, and there are all sorts of "accessories" that will stabilize parts will being turned (like a follow rest). Pretty much, I walked into their shop expecting them to say no as I was asking for too much, and they laughed like what I had given them was no challenge at all.
Unread 17-04-2009, 17:36
ginosoprano09's Avatar
ginosoprano09 ginosoprano09 is offline
Aldo Cruz
FRC #2585
ginosoprano09 will become famous soon enoughginosoprano09 will become famous soon enough
Send a message via AIM to ginosoprano09 Send a message via Yahoo to ginosoprano09
I really like ya'lls rollers , made from ABS eh?
care to mention where you got the material and how you machined them so nicely?
Just saw this robot in action and who could've imagined that it was going to be in your alliance
pic: Team 20 *2009* Robot bbr4d3r Extra Discussion 23 27-02-2009 21:07
pic: Team 604 2009 robot natalie604 Robot Showcase 10 20-02-2009 19:37
pic: Team 973 Upper Frame AdamHeard Extra Discussion 12 05-02-2009 11:18
pic: Team 973 Teaser 4.... is that pedro? AdamHeard Robot Showcase 13 03-02-2008 12:50
pic: Team 973 robot photo leak! Drwurm Robot Showcase 5 31-01-2008 19:26
