Go to Post I've never liked the pressure pads. This just confirms my suspicions: Pressure pads hate robots. It must be some inferiority complex or something. - Andy A. [more]
Unread 03-04-2009, 13:00
Steigerwald's Avatar
Steigerwald Steigerwald is offline
Questionable???
Steigerwald is an unknown quantity at this point
Send a message via AIM to Steigerwald
Re: pic: T-Shirt Launcher, still needs a chasis
I would like to point out that the components on that gun are not assembled correctly and they are not all pressure rated as you say. The components on the barrel are not assembled correctly. Those are also the components that are the most sensitive to blowing out because they receive a large pressure shock when the gun is fired.
You use a tapered bell reducer to go from the valve size to the barrel size. These components are not available in pressure ratings. While they are Schedule 40 components, that does not mean that they can be run at the same pressure as other schedule 40 parts. They take a large amount of force pushing them apart and because of that, they do not rate them for pressure.
Additionally, the components are not even pushed in all the way, this is very bad as the strength of the joint is based on the amount of material which is bonded together.
I would recommend you reconsider your design. I believe you are mistaken that this is acceptable for pressure. It is a great design and I would love to see it work, however, it is not safe and I would hate to see someone get hurt because of a explosion.
MVRT - Monta Vista Robotics Team #115
2009 Robot El Toro 13
2009 Davis Sacramento Regional Finalist
2009 Davis Sacramento Regional Engineering Inspiration Award
2009 Davis Sacramento Regional Best Website Award
2008 Championship Best Website Award
2008 Davis Sacramento Regional Best Website Award
2008 San Jose Best Website Award
2007 Davis Sacramento Regional Best Website Award
2006 San Jose Best Website Award
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
FVC World Championship still needs volunteers! vavex Championship Event 0 18-03-2007 18:09
pic: Current Robot Chasis Pnakovich Robot Showcase 13 13-02-2007 17:55
