Go to Post the FIRST season is never over . . it just pauses a while so you can get some sleep. - Stuart [more]
Unread 04-04-2009, 13:14
Steigerwald's Avatar
Steigerwald Steigerwald is offline
Questionable???
Steigerwald is an unknown quantity at this point
Send a message via AIM to Steigerwald
Re: pic: T-Shirt Launcher, still needs a chasis
It really does not matter whether there is a clog in the barrel. Assume there is one by some random occurrence. That would mean that the bell reducer which is not pressure rated would be experiencing the full pressure. Not only that, but when you open the valve, there is a sudden change in the pressure which causes a shock to the assembly making it more likely to blow out.
Every component on a project like this one has to be rated to the absolute maximum pressure that is to be put in. If air flows through a component, there is a chance that it will be at high pressure. Possibly not under normal conditions, but you should always plan for the worst.
MVRT - Monta Vista Robotics Team #115
2009 Robot El Toro 13
2009 Davis Sacramento Regional Finalist
2009 Davis Sacramento Regional Engineering Inspiration Award
2009 Davis Sacramento Regional Best Website Award
2008 Championship Best Website Award
2008 Davis Sacramento Regional Best Website Award
2008 San Jose Best Website Award
2007 Davis Sacramento Regional Best Website Award
2006 San Jose Best Website Award
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
FVC World Championship still needs volunteers! vavex Championship Event 0 18-03-2007 18:09
pic: Current Robot Chasis Pnakovich Robot Showcase 13 13-02-2007 17:55
