Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
Unread 04-04-2009, 18:40
EricH EricH is offline
Re: pic: T-Shirt Launcher, still needs a chasis
Originally Posted by Steigerwald View Post
I respectfully disagree, I believe that is exactly what is needed here. I think that people need to see that sometimes things that aren't expected happen.
I have seen that same argument that things don't have to be designed for the worst case scenario on our robot. Why do the construction properly the first time when you can just fix it in competition. Why over design something the first time when you can just make it work temporarily. It's things like that that make a huge difference.
Especially in elims, when that part that wasn't designed/built right fails suddenly because it took a load that it couldn't take.
Do it right the first time, and it'll keep going. Right, Mr. Lavery?
As for "How could a T-shirt jam?", most launched T-shirts are wrapped somehow for distance reasons. Usually, it's a rubber band or three. Guess what? Said rubber band or other wrapping has a much higher coefficient of friction than a T-shirt, and may stick in the barrel. The T-shirt then sticks too, and you suddenly have a jam. Now you have pressure that can't get the shirt out and can't go elsewhere. Your best bet in this case is to drain pressure immediately and use a stick to remove the shirt, but sometimes, it takes care of that for you, in spectacular fashion.
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
FVC World Championship still needs volunteers! vavex Championship Event 0 18-03-2007 18:09
pic: Current Robot Chasis Pnakovich Robot Showcase 13 13-02-2007 17:55
