Go to Post Also, I'm tired of the "FIRST is a simulation of the real world"-- it isn't. If the real world was like FIRST, there wouldn't be any need for this organization. - cadandcookies [more]
  #32   Spotlight this post!
Unread 04-04-2009, 18:46
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Re: pic: T-Shirt Launcher, still needs a chasis
Originally Posted by Steigerwald View Post
I think that people need to see that sometimes things that aren't expected happen.
Yes, but there is a point at which it reaches absurdity. Bringing up cases of bridges collapsing doesn't help anyone determine failure modes of a potato cannon.
I do agree though that this cannon should be able to withstand a T-shirt getting stuck in the barrel. I do see this as actually being a possibility due to T-shirts being pressed into the barrel too tightly, rubber bands around them increasing friction with the barrel, etc. That said, air will move through the T-shirts. I don't know how fast, but it might not be as bad as being completely clogged.
Anyway, on the subject of PVC. Why do I keep hearing stories about pressure rated PVC exploding? Air/water shouldn't make any difference regarding what pressure it fails at, only what happens AFTER the PVC fails.
Seems to me that if PVC rated at 400+ PSI fails at anything less than 400 PSI then it was either:
A) Not actually rated
B) Not properly used (exposed to conditions it wasn't rated for, etc.)
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
FVC World Championship still needs volunteers! vavex Championship Event 0 18-03-2007 18:09
pic: Current Robot Chasis Pnakovich Robot Showcase 13 13-02-2007 17:55
