Go to Post Have you hugged a Martian today? (Dave, don't answer that.) - Billfred [more]
  #31   Spotlight this post!
Unread 04-04-2009, 23:22
Steigerwald's Avatar
Steigerwald Steigerwald is offline
Questionable???
Steigerwald is an unknown quantity at this point
Send a message via AIM to Steigerwald
Re: pic: T-Shirt Launcher, still needs a chasis
Especially in elims, when that part that wasn't designed/built right fails suddenly because it took a load that it couldn't take.
Do it right the first time, and it'll keep going. Right, Mr. Lavery?
As for "How could a T-shirt jam?", most launched T-shirts are wrapped somehow for distance reasons. Usually, it's a rubber band or three. Guess what? Said rubber band or other wrapping has a much higher coefficient of friction than a T-shirt, and may stick in the barrel. The T-shirt then sticks too, and you suddenly have a jam. Now you have pressure that can't get the shirt out and can't go elsewhere. Your best bet in this case is to drain pressure immediately and use a stick to remove the shirt, but sometimes, it takes care of that for you, in spectacular fashion.
Well put!
The fact is that on this cannon, the barrel assembly is not made properly. The fittings are not inserted and some are not pressure rated. The need to be replaced to be safe. Period.
You asked for a way to solve the problem instead of just complaining? Fine, here you go!
Plumbing Supply
McMaster
I'll put up some pictures of what I have done which would work perfectly for your application.
MVRT - Monta Vista Robotics Team #115
2009 Robot El Toro 13
2009 Davis Sacramento Regional Finalist
2009 Davis Sacramento Regional Engineering Inspiration Award
2009 Davis Sacramento Regional Best Website Award
2008 Championship Best Website Award
2008 Davis Sacramento Regional Best Website Award
2008 San Jose Best Website Award
2007 Davis Sacramento Regional Best Website Award
2006 San Jose Best Website Award
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
FVC World Championship still needs volunteers! vavex Championship Event 0 18-03-2007 18:09
pic: Current Robot Chasis Pnakovich Robot Showcase 13 13-02-2007 17:55
