Go to Post I would say that you are not an engineer until you've both obtained the aforementioned peice of paper AND done something with your tumescent engineers forebrain. - phrontist [more]
  #35   Spotlight this post!
Unread 05-04-2009, 03:14
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Re: pic: T-Shirt Launcher, still needs a chasis
Originally Posted by squirrel View Post
A compressed gas has far more energy stored in it than a liquid compressed to the same pressure. It took a lot more work to compress the gas, and it's volume changed considerably. Liquids are "incompressible", meaning the volume will change very little while the pressure increases greatly. It's this energy that causes problems with pressurized air in PVC, the plastic can shatter and sharp pieces of it will fly at high speed all over the place.
Do you have a reference for this by any chance. I agree that compressed gas has more stored energy than a liquid under pressure, but it doesn't make sense that this would cause the PVC to fail, as long as the force exerted on the PVC remains the same in both cases.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
FVC World Championship still needs volunteers! vavex Championship Event 0 18-03-2007 18:09
pic: Current Robot Chasis Pnakovich Robot Showcase 13 13-02-2007 17:55
